Register/maintain reverse DNS entry
gck303
Currently I have a static IP address. I would like to register a servers into that IP's reverse DNS.
How can I do this?
I am in the process of setting up an iRedMail email server. The address below is a temperary domain which I am using for test purposes. Once this is working, I will transfer an active business's domain which is currently pointed to gmail.
I would like to register: mail-01.test6789.co.uk to 212.159.73.242
Thanks.
16 REPLIES 16
Fixes: 480
Re: Register/maintain reverse DNS entry
Moderators Note
This topic has been moved from ADSL Broadband to Everything Else.
bobpullen
Fixes: 331
The forward DNS record for mail-01.test6789.co.uk will need to point to your IP address before this can be done.
gck303
Thank you. I have maintained the DNS records. Yes, I should have done this before asking the question!
See below.
bobpullen
Fixes: 331
Thanks, that's now been requested for you (ref: INFOPS-75428).
bobpullen
Fixes: 331
@gck303 - should be sorted now and in the process of propagating.
gck303
Thank you. Our tests are all complete! We are ablew to setup an email server, and it seems to be nice and straight forward.
Please can this DNS entry be edited for our propery email server:
mail-01.camleyphotographic.com
The test6789 entry can now be removed.
Fixes: 1,665
I've raised the task (INFOPS-77849) for you now and the rDNS record should be set within 3 working days.
Fixes: 1,665
Hiya,
Can you create the A record for your domain to point it to your static IP? NetOps have come back to me now advising they're not able to do the rDNS until the A record's created.
Let me know once you've done that Smiley
gck303
Strange, I though this was already there.
The A DNS entry for mail-01 already points to our static IP. (212.159.73.242)
G
Fixes: 1,665
It's not pointing though to mail-01.camleyphotographic.com, which I believe is what you're wanting the rDNS set to.
U:\>nslookup 212.159.73.242
Address: 212.159.73.242
bobpullen
Fixes: 331
@Gandalf - you have things the wrong way round. Pointing the IP to a domain is exactly what @gck303 is asking to be done.
We now need to change the rDNS entry to point the IP to mail-01.camleyphotographic.com.
The forward record already exists: -
$ host mail-01.camleyphotographic.com
mail-01.camleyphotographic.com has address 212.159.73.242
Fixes: 1,665
Ah sorry. I think the response from NetOps confused me. Unsure why they rejected it when the A record was there. Sad
I've passed the task back to them to take another look. Smiley
Fixes: 1,665
Hi George,
After some back and forth with a colleague in the NetOps team, they suspect the reason they're unable to set the rDNS is because the MX records for your domain aren't created. Is this something you can do? Let me know if not though.
Cheers
bobpullen
Fixes: 331
Honestly shouldn't be required @Gandalf
Besides, the MX records already exist. Let me poke somebody Wink
