Register Long Arrays
- Everything else
- Re: Register Long Arrays
07-07-2009 3:32 PM
Is it possible to set Register Long Arrays to 'On' in php.ini? If so how please?
I would like to run JetPhoto.
Message 1 of 3
(1,766 Views)
2 REPLIES 2
07-07-2009 4:09 PM
If you are talking about our current CCGI platform, then unfortunately the answer is no. register_long_arrays was introduced in PHP 5.0.0, which is newer than the version on CCGI. It's also been dropped in PHP6 according to the documentation, so doesn't seem a popular option - there are performance implications in using it.
As for PAYH I'm not sure, however looking at the manual (again) it is on by default, so I would be surprised if it didn't support it.
Message 2 of 3
(386 Views)
08-07-2009 3:34 PM
Ben
Thanks for prompt reply. I have installed JetPhoto on my CCGI site - it seems to work ok notwithstanding the fact that the test script reports that register_long_arrays is 'off'. All other requirements seem to be met.
Message 3 of 3
(386 Views)
- Everything else
