Recent network changes?
FIXED- Subscribe to RSS Feed
- Everything else
- Recent network changes?
22-08-2026 8:14 PM
Also, I would request you to contact your Internet Service Provider (ISP) to verify whether your router’s security settings are blocking local queries or filtering incoming traffic. Specifically, ensure that ports 8443 and 443 are not being blocked, as these are essential for device communication.
Any info which points to a plusnet change (or lack of!) would be useful.
Chris
Fixed! Go to the fix.
Re: Recent network changes?
22-08-2026 8:36 PM - edited 22-08-2026 8:44 PM
@cmg
I do not know about this matter, but similar questions are raised here :
https://community.plus.net/t5/My-Router/hub2-firmware-inbound-80-443-problems/m-p/2056273
22-08-2026 8:54 PM
Thread moved from Broadband to Everything Else
23-08-2026 10:42 AM
Have you tried testing whether ports 443 and 8443 are externally visible using a port scanner such as GRC ShieldsUP! ?
26-08-2026 6:51 AM
Opening ports to a NAS puts you at risk of ransomware and attacks.
26-08-2026 10:37 AM
26-08-2026 2:43 PM
For the first few years did the NAS come with a subscription to an external service that has now expired ?
27-08-2026 6:54 AM
Exposing a NAS by opening ports (port forwarding) is typically done to access your storage away from home or to share files. However, direct port forwarding exposes your NAS to automated internet scans and potential exploits, making it a major security risk.
A safer approach for personal access is using a self-hosted VPN like WireGuard or a mesh network like Tailscale (both free). These can run on a compatible router, a Raspberry Pi, or the NAS itself, creating a secure, encrypted tunnel to your home network without exposing open web interfaces to the public internet.
27-08-2026 7:47 AM
I think the question from the NAS vendor was really, is the ISP blocking OUTBOUND connections to ports 8443 and 443.
Hopefully "Shields Up" and similar will show no response from any port for an incoming connection.
Generally the remote access to a NAS provided by the manufacturer has a mid-point at which you create an account.
The Synology version is QuickConnect
Synology NAS External Access Quick Start Guide - Synology Knowledge Center
Personally I would use a router that supports Wireguard and not use the NAS suppliers service. I really wouldn't forward ports on a router to a NAS.
That doesn't explain why yours has stopped working however!
27-08-2026 8:57 AM
27-08-2026 9:50 AM
I used to have a WD MyCloud.
It was the white one, 4TB.
It stopped being supported and it was painfully slow (even on the same LAN).
In the end I bought a Synology and used the drive in that. it was infinitely better than the MyCloud.
What you can't do is just move the drive. You have to transfer all the data.
If yours has stopped working, I might start with asking WD.
27-08-2026 10:38 AM
27-08-2026 5:39 PM
If you have a friend or relative where you could try the device on their connection it's probably worth a go.
I don't think it will help but it will provide some evidence to tell WD.
I also assume it's fine on your home network.
30-08-2026 8:16 AM
30-08-2026 9:44 PM
In the longer term, if you want to remotely access your NAS I recommend buying a router that supports Wireguard.
That removes any NAS manufacturer "man in the middle" and is fairly secure.
- Everything else
