Re: VPN not working
Roonie
Re: VPN not working
Hi - need assistance on VPN / Remote desktop...
Have a plusnet hub one - delivered this week - all works behind the firewall, including Remote desktop and VPN but am unable to access home network remotely... i.e. port forwarding appears not to work..
As far as I can tell, It is set up correctly on the hub.. I have a static IP address - what might be the problem?Huh
Any help appreciated
Chris
4 REPLIES 4
Fixes: 1,467
Re: VPN not working
Moderators Note
This post has been split from a different topic into a new thread for better visibility.
RichardB
Champion
Fixes: 34
Re: VPN not working
Hi Roonie,
Is the static IP address you refer to the LAN static IP address or a Plusnet assigned WAN static IP address?
You will need both.
If the VPN works in the LAN are you using a 192.168.1.x IP address to connect to it?
I do not use a Hub One router but I *think* I have read on these forums that port forwarding can be problematic, if the routers ship server is not used to assign the LAN IP address.
To keep the same LAN IP address after a router reboot etc, address reservation can be used.
Regards
Richard
Roonie
Re: VPN not working
Sorted.... Kaspersky firewall had blocked the ports!!!
Fixes: 1,552
Re: VPN not working
Sorry to hear you've had issues with your VPN, but I'm glad you've found the cause of the problem.
Let us know if you need any further assistance.
