Query re Providing a Service to a New Property
zeichen
Thanks for your simple explanation. Help please. We are currently on landline & FTTC with excellent speed [80bhp]& building new disabled home at bottom of garden, fencing it off & selling current home. We want new l/line & trf exist no. plus FTTC b/band. Is this possible? Openreach offered our builder only full fibre at cost to us of £2500, no alternative [which evidently they should if over £2,000]. We want service by February, fibre has just started being installed north of village where many more homes, we are south of village in rural location, cannot imagine them digging up the lane just for us! We cannot find any contact with Openreach, no phone no, email etc.  We also do not have a mobile signal so no cell phone unless wi-fi. We also have SkyQ so need this, satellite at present installed but using wi-fi. Help please, we dont want to pay £2,500 to find that fibre wont reach us for couple of years, we want to continue with FTTC but will need landline as no cell phone signal. Husband is 84 & disabled & vulnerable so cannot cope with anything very complicated, hence SkyQ & voice instructions.  Could you please give your recommendations. There is an existing telephone pole opposite the site entrance which could be used to send a line to the ridge of the proposed bungalow.  Any thoughts would be gratefully received.
We phoned Plusnet who didnt know what to suggest but arranged for an "expert" to phone us, but of course, never did!  Thanks
79 REPLIES 79
Fixes: 566
Re: FTTC and VOIP.
@zeichen your situation is going to be a little complicated!. Your new building should be allocated a UPRN (Unique property reference number). It should be allocated that by the local authority as part of the planning/construction process https://static.geoplace.co.uk/downloads/The-UPRN-lifecycle-V3-2015.pdf
Once you have that, then you can use the BT wholesale checker https://www.broadbandchecker.btwholesale.com/#/ADSL to determine what can be supplied to the premises.
The situation will be complicated by the fact that Openreach will no longer supply a landline based phone service and also if your exchange is fibre priority (doesnt sound like its likely to be) then only full fibre can be supplied.
As a start, if you already have a UPRN then sight of the results from the checker above will help people advise what is available. If not, then the results from your existing premises (using the post code and selecting the correct address) will still be useful.
NB in both circumstances, please redact any actual phone number/address information before posting as this is a public forum
Fixes: 108
Re: FTTC and VOIP.
@zeichen
Have you checked to see what is available at your current property ie is FTTP showing as available or coming. The Checker referred to previously may give an answer.
You can also check www.openreach.com to see what it says about FTTP for your property.
If it's coming to your current property then it should be easy to get to the new property (famous last words!!!). If it's not then you need to find out what they would charge to do both properties together. Installing FTTP to your current property should add value when you come to sell it.
There is a page on the OR site for developments where you can ask.
Fixes: 108
Re: FTTC and VOIP.
@zeichen
Another thought - have you registered with PN as a "vunerable" person if you are disabled? If not login in to your PN members page and have a look under Manage my Account (I think).
Any new phone service at the new property will be VOIP which PN do not offer.
zeichen
Re: FTTC and VOIP.
Thanks for the info.  Went into OpenReach and input address [both new build registered address & ours] message came up -
"Right now this property can’t access Full Fibre on our network and is in an area where we currently don’t have any major plans to build. This could change in the future and we'll let you know if we plan to start building in this area or Full Fibre becomes available under a smaller build programme. We’re announcing updates all the time as we’re aiming to build Full Fibre to 25 million homes and businesses by 2026 and we’re not stopping there. We intend to keep building after that too."
When I asked for broadband, it kept returning to Full Fibre and would not accept anything else.  At the north of the village they started laying fibre and then had to stop because of problems with the drains. So of, if they wont provide FTTC & full fibre isnt planned down this part of the village, how can we proceed. Who can provide a  landline as no cell signal [even if VOIP in the future] and broadband.  Do we have a right to connectivity or is a matter of bad luck, you wont have anything?
This is very worrying as no cell phone, land line or wi-fi we would be cut off completely especially for emergencies.
Fixes: 566
Re: FTTC and VOIP.
As I said above , what does the BT wholesale checker return for the two properties ?
Fixes: 108
Re: FTTC and VOIP.
@zeichen
To echo @MisterW  what does the Checker say. The narrative below the results window is as important as the results themselves.
You're particularily looking for anything that says SOGEA.
zeichen
Re: FTTC and VOIP.
The checker says -
FTTP is not available.
The exchange is not in a current fibre priority programme  As a WLR withdrawal exchange, product restrictions apply
SOADSL is not restricted at the exchange
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage. For all SOADSL services,the stable line rate will be determined during the first 10 days of service usage.  Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
ADSL, ADSL2+ and SOADSL availability: If shown at FTTP or SOGEA premises,ADSL, ADSL2+ and SOADSL are not available to order due to WLR Withdrawal stop sell rules. CPs should order FTTP or SOGEA. Copper products are only available by exception
the other message
same for both properties.  If I try and check on the other options, it returns to the same message.
Fixes: 108
Re: FTTC and VOIP.
@zeichen
Thanks for the information.
It appears SOGEA is not available - this is FTTC without a phone line.
SOADSL may be available - this (I believe) is a form of digital ADSL or may even just be ADSL.
To repeat an earlier question - have you registered as a vunerable person (if you are disabled)? If there is a disabled person in the house you may still be able to register. This matters as OR and ISP's have to look after vunerable people during the switchover.
Try phoning PlusNet Customer Options Team on 0800 013 2632 and explain the situation. They should be able to tell you what's available at the new address. Whatever is, you would have to port your phone number to a VOIP provider.
To go back to OR - was it you or your builder who was quoted the price for providing FTTP? Either way, you could try getting back to them to see if two properties to be connected makes a difference.
Fixes: 566
Re: FTTC and VOIP.
without the actual availability results display , that's difficult to know !
Fixes: 368
Re: FTTC and VOIP.
Sorry to jump in, but if @zeichen currently has FTTC, I would be quite amazed if SOGEA wasn't available, although as said above, without  the availability results, we are all guessing.
zeichen
Re: FTTC and VOIP.
I have registered with Plusnet as Disabled and we are both vulnerable,I will phone again tomorrow to see if Plusnet can help, but not so far.  The biggest problem is there isnt an Openreach phone no to ask for details or an email.  Have tried to find anyone from Openreach who could help, but no luck.  The quote was for the new build connection to Fibre, but as there is no Fibre in the village how can they quote for a connection early next year? We havent sold this house so havent been concerned about our present connection as no one has warned us that we will lose our landline.    I am in 2 yr contract with Plusnet for phone and broadband till next September with exit fee so surely they must honour voice until then?  We cannot ask for joint connection if there isnt any fibre in the locale [within a mile] I dont know where it starts from as the lane in the north of the village is still closed for fibre so isnt even installed there yet.  All I want to know is how we can have a phone line and broadband from 1st February, but it seems no one is able to answer and Open Reach dont have a help contact.  I seem to be going round in circles!
Fixes: 368
Re: FTTC and VOIP.
@zeichen Can you please post a screenshot of the top section of the site from which you obtained the narrative you have posted - that will give members on here a much clearer picture, from which we can try and offer advice.  Please obscure any phone numbers/addresses though.
zeichen
Re: FTTC and VOIP.
Telephone Number  on Exchange IPPLEPEN is served by Cabinet 2
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Handback
Threshold(Mbps)
WBC FTTC Availability WBC SOGEA Availability Left in Jumper
High Low High Low
VDSL Range A (Clean) help 80 71.1 20 19 65.1 Unavailable Available --
VDSL Range B (Impacted) help 80 68.3 20 19 60 Unavailable Available --
G.fast Range A (Clean) help -- -- -- -- -- Unavailable -- --
G.fast Range B (Impacted) help -- -- -- -- -- Unavailable -- --
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install Process
FTTP on Demand 330 50 -- Available --
Observed Speeds VDSL
Max Observed Downstream Speed 80
Max Observed Upstream Speed 20
Observed Date 2024-03-04
Other Offerings Availability Date
VDSL Multicast Available
Premise Environment Status
Bridge Tap N
VRI N
NTE FacePlate N
Last Test Date 08-10-2024
Exchange Product Restrictions Status
FTTP Priority Exchange N
WLR Withdrawal Y
SOADSL Restriction N
ADSL, ADSL2+ and SOADSL availability: If shown at FTTP or SOGEA premises,ADSL, ADSL2+ and SOADSL are not available to order due to WLR Withdrawal stop sell rules. CPs should order FTTP or SOGEA. Copper products are only available by exception.
Thank you for your interest
Hope this means something to you??? Thanks
Fixes: 241
Re: FTTC and VOIP.
In simple terms it is not possible to get new WLR (POTS) telephone service except in exceptional circumstances, though I do not see that is such here.
FTTP is not yet available in your location.
Therefore your service provision would be SOGEA (FTTC without POTS). If you want to move the landline number to the new property then that will need to be a VoIP service.
If you want to keep broadband and voice provision with the same supplier there are plenty to choose from. Plusnet will waive ETCs if you ask them to migrate you to BT + Digital Voice.
You could also do a house move on the FTTC broadband contract (it become SOGEA) which releases the phone number which you can transfer to VoIP within 30 days.
Home moves are managed by the Customer Options Team.
