Problem with Google search
famrichards
Intermittently for every search in Chrome, i get this
This site can’t be reached
Check if there is a typo in www.google.com.
when I do an nslookup on www.google.com i get-
$ nslookup www.google.com
;; connection timed out; no servers could be reached
At other times when search is working I get this-
$nslookup www.google.com
Server: 127.0.0.53
Address: 127.0.0.53#53
Non-authoritative answer:
Address: 142.250.187.196
Address: 2a00:1450:4009:815::2004
This happens both from my Ubuntu Desktop and my Android mobile. If I use a 4G connection on my mobile all is fine so looks like a problem with my plusnet connection.
Any help would be appriciated its been going on for weeks now.
Tags (1)
2 REPLIES 2
RPMozley
Seasoned Pro
Fixes: 18
Re: Problem with Google search
What router are you using?
Also please set alternative DNS servers to test it’s just a DNS issue.
That's RPM to you!!
famrichards
Thanks for the reply.
My router is a Draytek Vigor 2820
I've set my DNS to 8.8.8.8 and 8.8.4.4
it was just set to automatic.
Lets see if this helps.
Bruce
