Problem With Member Centre
Total_Chaos
I don't know if others have had the issue with the Member Centre Data not displaying after login. Login the welcome message displays for about two seconds and then disappers with the footer moving up to the header with white space below. This started Wednesday or Thursday afternoon while I was logged. I have tried on my Linux box, Andoid based tablet and phone, trying with Firefox, Brave, and Vivaldi, all with the same results. The router, an Asus, has also been restarted. I think that this is likely a coding issue. Everything other than the Member Centre appears OK.
2 REPLIES 2
Fixes: 389
Re: Problem With Member Centre
@Total_Chaos See: https://community.plus.net/t5/Everything-else/Plusnet-Broadband-portal-not-displaying-correctly/td-p...
I'm not convinced this is a 'coding' issue - I have no issue accessing the Members Centre on either Windows, Linux or iOS. All browsers are Firefox.
Mav
Fixes: 518
Moderator's note(s):
Thread locked in favour of the link above.
Forum Moderator and Customer
