Plusnet Firewall issue
adam945
Fixes: 113
Re: Plusnet Firewall issue
Hello @kissinuk
Thanks for getting in touch, I've just checked the open incident on our end end we still don't have a resolution date to be honest, please accept our apologies for the inconvenience caused here.
 Adam
 Plusnet Help Team - Leeds
akrypzs
Just tried modifying the firewall settings this morning.  Although it does not appear to have rectified my own issue, I can confirm that I can now successfully adjust the firewall settings (Off, Low, High and specific common port options).
Fixes: 1,662
Thanks for the update @akrypzs
I'm glad to see you can adjust your firewall settings now. I've just checked the open incident and I can see we confirmed this as resolved last Friday, though the fix for the issue rolled a few days before then.
kissinuk
Thank you, I can confirm my VPN is now working again!
Fixes: 1,662
Excellent! Cheers for the confirmation @kissinuk
