Plusnet Broadband portal not displaying correctly
Fixes: 357
Re: Plusnet Broadband portal not displaying correctly
Didn't realise, @davidj66  (and sorry again, @sharon1 )
sharon1
No apologies necessary @jab1! It's so kind of you to try and help fellow Plusnetters 😊
Fixes: 357
I'm not a 'Plusnetter' any more, @sharon1 , just an ex-user who enjoys trying to resolve problems. 😀
sharon1
@jab1 That makes it even more kind! 😁
Fixes: 1,652
@davidj66, @critch@street7cat
I've added your accounts to the investigation (ref: IMT-8126)
Total_Chaos
Gandalph, Can you add my account to that investigation.  Started happening Wednesday or Thursday afternoon of last week, and continues.
Fixes: 1,652
I've added you now @Total_Chaos
sharon1
So - I found this was also a problem a few years ago -
https://community.plus.net/t5/Plusnet-Feedback/Plusnet-home-page-loading-problem/td-p/1533309
It seems it got fixed pretty quickly then 😢
Fixes: 1,652
We're still actively working on the problem to fix as soon as possible.
halbot
Go developers!
bobpullen
Fixes: 330
Not quite the same cause.
AIUI, a fix has been coded but will need to go through the appropriate governance/code release controls before it is made live.
sharon1
Thank you for this update! Great news. Thanks all round, really 😊
Tigger
Tried to log in today for the first time in a long time, only to run into this problem!
Can you add me to your list, please?
Dev
Still having this problem both on Edge and Chrome.
Fixes: 357
Because it has not yet been resolved, unfortunately.
