Phone calls over VOIP
greygit1
If a VOIP connected phone (or another cell phone) is calling another cell phone then what would be the reasons for no ring tone and the connection falling through to voicemail? (Barring the event that the cell phone was without power).
Could it indicate a lack of mobile network coverage?
2 REPLIES 2
Re: Phone calls over VOIP
Maybe the person you are phoning has a nuisance caller blocking app on their mobile, and your caller ID is on their block list ?  Wink
Fixes: 585
The destination mobile not having a network signal is the likely cause. The fact that the call originates over VOIP is not significant.
