PHP script wont work
- Everything else
- PHP script wont work
02-11-2007 5:13 PM
Can someone tell me why this simple little image rotation script refuses to work?
http://robm.me.uk/articles/image-rotation-in-php
I followed it to the letter, yet when I link to the rotate.php file it refuse to work. Is there something I need to activate for my webspace to recognise this?
Message 1 of 6
(2,410 Views)
5 REPLIES 5
Re: PHP script wont work
02-11-2007 5:25 PM
This needs to run on your ccgi webspace, is that where you are runing it. It won't work on your www webspace.
You may need to activate CCGI via member centre.
Message 2 of 6
(537 Views)
02-11-2007 5:55 PM
This is on my ccgi webspace, the link to the file is :-
http://ccgi.azagoth.plus.com/sigs/rotate.php
Yet it's not working for some reason, and I'm not exactly an expert when it comes to all this stuff.
Message 3 of 6
(537 Views)
02-11-2007 5:57 PM
You need to set the permissions on the file to 750 using either chmod via the shell prompt, or within your FTP program used to upload the file.
See the usertools tutorials about accessing the ccgi server via cshell and about file permissions.
Message 4 of 6
(537 Views)
02-11-2007 8:39 PM
Aha! Thanks, it seems to be working now.
Message 5 of 6
(537 Views)
02-11-2007 9:43 PM
IE7 is fine but it does not work in firefox 2 so you may need to query that with the developers.
Message 6 of 6
(537 Views)
