PHP Problems
- Everything else
- PHP Problems
PHP Problems
11-04-2008 1:57 PM
Hi
I am currently trying to create a website that allows a user to obtain a quote by sending me their details using a form that calls a PHP script. The script should generate an email to myself containing details of the quote.
I continue to get the following error:-
405 Method Not Allowed
e3
Method Not Allowed
The requested method POST is not allowed for the URL /quote.php.
0
Here is the code:-
Any ideas?
Thanks in advance
e3
Method Not Allowed
0
Here is the code:-
<?php
$mailto = 'bookings@deejays.plus.com' ;
$subject = "Booking Form" ;
$formurl = "http://www.deejays.plus.com/quote.html" ;
$errorurl = "http://deejays.plus.com/error.html" ;
$thankyouurl = "http://www.deejays.plus.com/quotecomplete.html" ;
$uself = 0;
$email_is_required = 1;
$name_is_required = 1;
$headersep = (!isset( $uself ) || ($uself == 0)) ? "\r\n" : "\n" ;
$email_required = (!isset( $email_is_required ) || ($email_is_required == 0)) ? 0 : 1 ;
$name_required = (!isset( $name_is_required ) || ($name_is_required == 0)) ? 0 : 1 ;
$name = $_POST['name'] ;
$email = $_POST['email'] ;
$comments = $_POST['comments'] ;
$http_referrer = getenv( "HTTP_REFERER" );
if (!isset($_POST['email'])) {
header( "Location: $formurl" );
exit ;
if (($email_required && (empty($email) || !ereg("@", $email))) || ($name_required && empty($name))) {
header( "Location: $errorurl" );
exit ;
if ( ereg( "[\r\n]", $name ) || ereg( "[\r\n]", $email ) ) {
exit ;
if (empty($email)) {
$email = $mailto ;
if (get_magic_quotes_gpc()) {
$comments = stripslashes( $comments );
$messageproper =
"This message was sent from:\n" .
"$http_referrer\n" .
"------------------------------------------------------------\n" .
"Name of sender: $name\n" .
"Email of sender: $email\n" .
"------------------------- COMMENTS -------------------------\n\n" .
$comments .
"\n\n------------------------------------------------------------\n" ;
mail($mailto, $subject, $messageproper,
"From: \"$name\" <$email>" . $headersep . "Reply-To: \"$name\" <$email>" . $headersep . "X-Mailer: chfeedback.php 2.10.0" );
header( "Location: $thankyouurl" );
exit ;
Any ideas?
Thanks in advance
Message 1 of 7
(1,492 Views)
6 REPLIES 6
Re: PHP Problems
11-04-2008 2:09 PM
You can't use php on the homepages server, it has to go on the ccgi server.
Message 2 of 7
(297 Views)
Re: PHP Problems
11-04-2008 2:11 PM
Can't you use http://www.plus.net/support/webspace/cgi_php/cgi_scripts.shtml instead of rolling your own?
Message 3 of 7
(297 Views)
Re: PHP Problems
11-04-2008 3:39 PM
Quote You can't use php on the homepages server, it has to go on the ccgi server.
Cheers Jelv
Do I need to upload just the php script to the ccgi server and link to it or the whole website?
Message 4 of 7
(297 Views)
Re: PHP Problems
11-04-2008 5:36 PM
Just the php file. It's looking good with what you have done.
Message 5 of 7
(297 Views)
Re: PHP Problems
11-04-2008 6:28 PM
Yeah I got it sorted. I should of put my brain in gear before my mouth and tested before asking silly questions.
Got your test email Jelv.
Cheers again.
Have a problem now that if the the file is filled incorrectly I recieve this error when the content of error.html should be displayed:-
Web Server Error Report:
Server Error: 501 Not Implemented
No RPM for this combination of URL and method
/error.html
I'm new to html and scripting you see, although I can program a little in C and Java.
Trying to debug now
Cheers again.
/error.html
Trying to debug now
Message 6 of 7
(297 Views)
Re: PHP Problems
12-04-2008 12:29 PM
Right,
You've put the PHP Script on the CCGI Server,
and not put "error.html" (according to the error described) in the Root of the CCGI Space,
of course it won't show an error because the file doesn't exist.
Another solution is to use Header Redirection, and back that up with a HTML Redirect on the page just incase of poor browser HTTP response handeling:
I'd check out alittle on FORM's and HTTP Protocol so you understand (if you don't already) the difference in Packet Structure of a HTTP Request especially reguarding "GET" and "POST" Method Variables / Values in PHP.
(PHP Predefined Arrays for GET / POST Variables: $_GET[] / $_POST[] Member names from "NAME" Field in HTML)
As you could have the Form on your WWW Space that just utilises the CCGI Space and swiftly returns the user to the WWW Space with your other HTML Files it would appear relatively seemless.
Be careful where you place these,
as you cannot send Header Directives after you've echoed/printed for output.
is a big no no. PHP will tell you as well / the script might cry
Nice to know you've used other programming languages of a similar style,
that helps 90% of the time
C - is good,
Java - not so good in my opinion xD but what ever floats your boat.
Hope some of that helps!
Jim,
Header('Location: www.deejays.plus.com/success.html');
echo '
<META HTTP_EQUIV = "REFRESH" CONTENT = "2; url=http://www.deejays.plus.com/success.html">';
echo 'Hello';
C - is good,
Jim,
Message 7 of 7
(297 Views)
