PHP: Dynamically Creating Thumbnails
- Everything else
- Re: PHP: Dynamically Creating Thumbnails
11-09-2007 10:24 AM
Hello there,
I would like to dynamically create some image thumbnails. I have written a php file, getThumbnail.php, that I call during every iteration of a for loop. However, the unexpected result is thus:
all the thumbnails are the same, they are all of the last image in the directory.
Other than that, the result is as expected.
Does anyone know why this happens? How can I fix it?
Thanks in advance,
Logical
Code:
index.php:
getThumbnail.php:
Thanks in advance,
Logical
Code:
index.php:
for($i = 1; intval($i) <= intval($total); $i = intval($i) + 1)
$photo = $album . $i;
$filename = $photo . '.jpg';
$image = './' . $album . '/' . $filename;
$_SESSION['image'] = $image;
<img src="getThumbnail.php" />
getThumbnail.php:
session_start();
$file = $_SESSION['image'];
$size = 0.45;
list($width, $height) = getimagesize($file);
$modwidth = 80;
$modheight = 80;
$tn = imagecreatetruecolor($modwidth, $modheight);
$image = imagecreatefromjpeg($file);
imagecopyresampled($tn, $image, 0, 0, 0, 0, $modwidth, $modheight, $width, $height);
imagejpeg($tn, null, 100);
Message 1 of 3
(1,602 Views)
2 REPLIES 2
11-09-2007 10:50 AM
You don't need the intval in the for loop.
Do you have a session_start() in index.php?
I'm note sure what you are trying to do by having HTML code (<img src="getThumbnail.php">) within the php section as that will not work.
I would pass the filename as a parameter rather than using $_SESSION[] as its likely the $_SESSION[] has not been saved to disk before it is used within getThumbnail.php
index.php
getThumbnail.php
index.php
for($i = 1; $i <= $total; $i += 1)
<img src="getThumbnail.php?<?php echo $image ?>" /><br>
<?php
getThumbnail.php
$file = $_GET['file'];
$size = 0.45;
$modwidth = 80;
$modheight = 80;
Message 2 of 3
(465 Views)
11-09-2007 2:24 PM
Thanks. It all works fine.
Message 3 of 3
(465 Views)
- Everything else
