Old Openreach FTTC box - recycling?
Mike37
I've just successfully upgraded from FTTC to FTTP. I have been left with the old Openreach FTTC "modem" which is now redundant. I understand Plusnet will recycle their own routers. But not sure how to recycle the old Openreach box - would this be via Plusnet or Openreach?
5 REPLIES 5
Fixes: 110
Re: Old Openreach FTTC box - recycling?
@Mike37
Is it a TG5852n box?
https://www.plus.net/help/broadband/router-setup-guides/
If it is you can return it via PN. I returned one last week.
https://www.plus.net/help/broadband/returns/
Mike37
It's a Huawei EchoLife HG612.
Fixes: 110
@Mike37
If you have an eBay account I believe you might get a few quid for it.
Otherwise any local re-cycling centre that takes small electrical goods.
markhawkin
Aspiring Champion
Fixes: 20
With a power supply, it typically sells for around £20.
Fixes: 1,495
Moderators Note
This topic has been moved from Full Fibre to Everything Else
