Nextdns DoT blocked on connect
- Everything else
- Nextdns DoT blocked on connect
28-11-2021 2:21 PM
If I have private dns on in Android 12, using nextdns for DoT I connect to my wifi but it says no internet and I cannot browse anywhere, however once I disable this I'm ok, but if I then reenable it it works, so it's only not working on the initial connection. Is there a reason for this? It's a pain disabling-enabling this every day on devices, but it clearly 'works' once connected. Any help would be great!
Message 1 of 2
(948 Views)
1 REPLY 1
Re: Nextdns DoT blocked on connect
02-12-2021 12:08 AM
Sounds like a NextDNS issue if DoT works without it but doesn’t work with it. Although I’m not actually sure what DoT is. It may be worth getting in touch on their forums here https://help.nextdns.io as people over there may have more of an idea. I hope this helps. ![]()
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
Message 2 of 2
(853 Views)
- Everything else
