New EE mobile packages via Plusnet
robski1
Fixes: 7
I moved to EE Mobile 2 years ago as Plusnet started phase out their service.
All has been OK but EE are going to move me to a new package that is not what I want.
I see that Plusnet have a link to a £6 EE deal that would meet my needs.
Does anyone know if I will be able to port my existing EE number to the new Plusnet EE package.
I have spoken to EE and they seem to be unaware of the deal and would not look into it for me.
Any help would be great. Sorry if I have posted this in the wrong place
5 REPLIES 5
mystreet1
Seasoned Pro
Fixes: 7
Re: New EE mobile packages via Plusnet
You cannot port a number from / between the same supplier. Best to find the PlusNet EE deal and ask EE if they will honour it.
If not, look at porting your number to a virtual mobile network that runs on the EE network if that is the best network for you.
Other networks may be better.
Normally, other networks also do not have a yearly price rise.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
robski1
Fixes: 7
Thank you for your advice. If I went to a virtual network can I still keep my number?
mystreet1
Seasoned Pro
Fixes: 7
Yes, just port in the number. Some ask you for your PAC on sign up. Best to find a supplier first check that you are happy with the service, then port in your number. You will need a PAC. Text PAC to 65075 from your existing number. They are valid for 30 days
mystreet1
Seasoned Pro
Fixes: 7
https://www.uswitch.com/mobiles/compare/sim_only_deals/
Filter for EE networks, Spusu, £6.90pm, 20gb data, or £2.90 pm for 1gb data
robski1
Fixes: 7
Thanks for all your help. I will have a look at what's available.
