New Battery Backup Unit
Fixes: 118
6 REPLIES 6
Re: New Battery Backup Unit
Some more details on the BBU and where to buy one
https://getgofone.co.uk/products/broadband-battery-backup-bbu
paul_blitz
Fixes: 4
I bought one from Ali Express, it cost a LOT less than that, and it's been in circuit for a while now, doing its job perfectly.
Would definitely suggest SOME form of Battery Backup, especially if you are looking to go VOIP.
outcast
Aspiring Champion
Fixes: 19
@paul_blitz  does it have user replaceable batteries or is it a sealed unit or require prying tools to open ?
I've looked at the specs and tried to find the user manual, but haven't seen any mention of replacement batteries.
paul_blitz
Fixes: 4
Good question... and I think it is sealed (otherwise I'd have had a look at the insides, and I don't remember doing so!).
Having said that, it was sufficiently cheap that you could just replace the whole thing about 6 or 7 times before hitting the same cost as the one that was in the original post! In fact it's probably cheaper than what we would pay for the batteries!
outcast
Aspiring Champion
Fixes: 19
Does that front panel USB connector have any comms capability ?
On all my various UPSes, I use the USB or RS232 comms to perform a managed controlled shutdown of the connected broadband router, PCs, servers, etc, when the UPS battery has drained to the point where it will soon shut off the power, to minimise the chances of corrupted files, and to gently shut down the DSL PPP session before the line drops.
paul_blitz
Fixes: 4
Another thing to watch out for is the connector supplied to power your router / hub: the plusnet hubs (old and new) seem to use s VERY non-standard size of connector, I was completely unable to find one (and I spent some time looking!), so ended up making my own cable, by cutting the end of the existing mains supply (I had a spare one!)
