Netfix blocked by Plusnet
thursosmith
No matter what I do I cannot connect to NETFLIX.
Moderator's note by Mike (Mav): All caps title/text edited as per Forum rules.
4 REPLIES 4
Fixes: 480
Re: NETFLIX BLOCKED BY PLUSNET
@thursosmith  Welcome to the forum.
As far as I am aware you cannot ‘connect to Netflix’. Netflix is an App that runs on a Smart TV or computer. Why not explain in detail what you are trying to do and hopefully we can advise.
thursosmith
When I press NETFLIX on my t.v. remote NETFLIX will not connect, it says not connected to internet although it is wired connection and has always worked up until a few days ago.  NETFLIX says that it is a server problem.
thursosmith
CODE NW-1-19  Not connected to the internet.
thursosmith
For some strange reason after posting on here it has started working again. Lets see how long it lasts.
