Moving from PlusNet FTTC to PlusNet FTTP with BT phone contract
Fixes: 579
Re: Moving from PlusNet FTTC to PlusNet FTTP with BT phone contract
seems odd that the PN Agent seemed unaware of the process -
i suspect they misunderstood and thought you wished to retain the landline as it was with BT
@TBSteve wrote:
... not much different in price between 145 and 500 - odd that 300 is more than 500 -I guess I was falling for the supersize me offer.
Fair enough !
You could spend that £60 per year difference on a decent router that supports traffic QoS (which the Plusnet Hub-2 doesn't)
TBSteve
My offers are different prices - FF145 is more expensive so only £24/yr difference between 145 / 500
Well that makes your decision easier !  😀
Given that there is a difference between prices on our screenshots, perhaps you should contact Plusnet sales to haggle the lower price if you wanted to go for FF145 ?, otherwise just go for FF500.
TBSteve
I believe the cheaper prices ( plus reward cards ) is for new customers
Yes, but that is typically an indication of how low Plusnet sales/retentions will haggle down to for existing customers who are willing to challenge their renewal/offer prices.
Anyway, good luck with your upgrade !
