Move domain to IONOS
griggs789
I'm sorry if this has been asked before but I can't find the answer.
As I require https on my website I have decided I want to move my domain to IONOS. I've red about IPStag but I can't find where or what it is.
Could you help me please?
Thanks,
Pete.
4 REPLIES 4
spile
Re: Move domain to IONOS
I’d strongly recommend more research. Many horror stories about that host with users struggling to leave them and support poor. There are much cheaper and better hosts that won’t lock you in.
mystreet1
Seasoned Pro
Fixes: 7
One I would recommend is simplereg.com
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
Tina11192
Fixes: 18
@griggs789  Thank you for reaching out to us on our Community Forum, I hope you are well.
The IPS tag is provided by the taking over provider, this is usually a word unique to the provider and you will need to contact them directly through their website/support channels.
Once you have the IPS tag please do get back in touch with us so that we can start the process for you.
I hope this helps
Cri Ignatti
griggs789
Thanks for the replies. I have now transfered to SimpleReg. They were very helpful and got me through the process.
