McAfee VPN with Plusnet
WorldMachine
I have discovered that VPN is available on McAfee,  I have McAfee as part of my Plusnet service however, I cannot find how to activate it.  The VPN tile referred to is not there,  Is McAfee VPN available on the Plusnet service?  If so, how do I activate it?
2 REPLIES 2
Fixes: 579
Re: McAfee VPN with Plusnet
I believe McAfee VPN is a paid for product , unless you only use 250Mb/month, So its not part of the standard PN offering.
In any case , before you attempt to use it , I would suggest you read this https://techjury.net/reviews/mcafee-vpn-review/#gref
In particular the section 'McAfee Safe Connect VPN privacy and Jurisdiction' about half way down the article
WorldMachine
Thanks for the info; I had seen similar reviews saying you are essentially handing over your information to them, but I thought if it was part of the package I'd try it.
