Lloyds site unreachable
FIXED- Subscribe to RSS Feed
- Everything else
- Lloyds site unreachable
30-10-2016 10:23 AM
I have been unable to access Lloyds Bank site for three days.
The bank help desk remarks "It must be your provider".
Plusnet phone queue has 45 waiting clients so that is not a valid option.
Anyone else had this problem with Lloyds?
(no problem with other banks by the way)
Fixed! Go to the fix.
Re: Lloyds site unreachable
30-10-2016 10:32 AM
Nope, it's working for me, as in prompting for UID, Password as a site but I'm not a customer.
30-10-2016 11:13 AM
Thanks for that..but still the same here
30-10-2016 11:25 AM - edited 30-10-2016 11:27 AM
30-10-2016 11:29 AM
I use that site. The only minor hiccup is that quite often it appears unavailable at first, but immediately clicking on "Try again" always then gets there.
30-10-2016 11:30 AM
30-10-2016 11:40 AM
I'm with Lloyds Bank and @Anonymous's link is the one I normally use.
30-10-2016 11:42 AM
Thanks for the interest Mook!
40.127.139.252 also gives me Azure
I run Debian 8, ipconfig is not a feature I think...I have tried to flush the cache but apparently there isn't one!
kdiment -- regrettably 'Try Again' doesn't work for me....
I tried the link Mook posted and successfully reached the site..hoorah...BUT...trying the personal banking tab resulted in the same no server notice...
It's enough to make me want to move banks ...after more years than I care to remember...or ISP's....possibly
30-10-2016 11:48 AM - edited 30-10-2016 11:49 AM
Didn't understand about 'lithium'--brief research didn't help....I'll try again later with that topic...
Happy to hear your access is as usual though.
30-10-2016 12:06 PM
Just to clarify, I use @Anonymous's link (https://www.lloydsbank.com/) but I use Google's DNS and can access the personal banking tab.
30-10-2016 12:06 PM
30-10-2016 12:22 PM
I installed ncsd and restarted this daemon but without effect I'm afraid.
dns-clean does not exist on my system and Synaptic and/or apt-get doesn't know about it...stymied!
Browni suggests using Google's DNS - more research on my part is needed .....
Much appreciate the help from all.
30-10-2016 12:35 PM - edited 30-10-2016 12:36 PM
@TW - Well it wouldn't if you've only just installed it!
To change your dns edit your resolv.conf
sudo nano /etc/resolv.conf
nameserver 8.8.8.8
nameserver 8.8.4.4
This assumes the nano editor is installed of course.
30-10-2016 12:50 PM
Upgrading my bookmark Mook, as you suggested, now allows access to the main site but the personal banking tab still 'falls down'
With dns edit I assumed that installation and then reboot was all that was required,,,I'll do it properly this time and adjust resolv.conf as you suggest, retry and then say how I got on.
30-10-2016 1:25 PM
If by 'dns edit' you mean changing your resolv.conf then you shouldn't need a restart, it's not Windows you're running
- Everything else
