Linking to common HTML
- Everything else
- Linking to common HTML
04-05-2008 1:11 PM
I am no expert on this, but I am working on a new website for my archery club, and teaching myself some CSS into the bargain. There is a common chunk of html in all the pages which has the content of a sidebar with the main menu and news headlines. There aren't that many pages, so it is not too big a deal to copy and paste them all when I do an update, but I would like to find some simple way of having one chunk of html that all the pages link to.
I know I could use frames, but I would rather not. I would just like to put a separate small html file into the flow in the same way as you would with an image. Any ideas?
Message 1 of 7
(1,377 Views)
6 REPLIES 6
Re: Linking to common HTML
04-05-2008 1:36 PM
You could use server side includes. You put the common code in a separate file and then where you want it to appear you have
The path is required if the included file is not in the same directory.
The will also need to make additions to .htaccess to tell the webserver which pages should be checked for includes
All my pages which have includes are shtml not html. You could enable it for html but that means it will check for includes on all web pages before they are delivered.
<!--#include virtual="path/includefile.xxx"-->
AddHandler server-parsed .shtml .htm
AddType text/html shtml htm
Message 2 of 7
(208 Views)
04-05-2008 8:05 PM
Thanks, jelv, that looks like the kind of thing I need.
The whole point is that all the pages have the same bit of code, so it will have to check all the pages anyway. I might add this is not hosted by PN, so I guess I'll have to check that the host has that enabled.
Message 3 of 7
(208 Views)
04-05-2008 11:54 PM
What software are you using as some like MS Expression let you have a master page and all other pages come from that page so if you chamge the master page it changes every page in the site simple.
You can get MS Expression as a free trial
Message 4 of 7
(208 Views)
05-05-2008 12:02 PM
MS
spit, spit. No, using Suse 10 on a desktop and Ubuntu 7.10 on a lappy. I use Kompozer, but also doing it manually with a text editor.
You would have thought there would be a way of doing it in html, e.g. <html src="xxx.html"> or somesuch, but no, that would be too easy. Server side includes seem to be simple enough, though, unless anyone has any better ideas.
Message 5 of 7
(208 Views)
05-05-2008 11:04 PM
You could do most of it with CCS as that can handle the menu etc depending what the news is? Using the same CCS for ever page would solve it
Message 6 of 7
(208 Views)
06-05-2008 5:03 PM
I already have a single styleheet for all the pages. Surely the whole point of CSS is that is does not include content? The style is in the CSS, the content is in the HTML. The content of the common section i.e. link addresses, text etc has to be in the HTML.
Message 7 of 7
(208 Views)
- Everything else
