Landlines are going digital
Fixes: 387
Re: Landlines are going digital
The installation engineers normally know what they are doing, and do it well.
Fixes: 118
@greengrass
As an aside, there's nothing to stop you changing out the routers now. With the Hub2 up and running change the WiFi credentials in the Admin pages of the router and that's the Hub2 sorted.
Cometh the day and cometh the hour you simply change the DSL lead with the Ethernet cable.
Fixes: 387
Good point, @bmc , so long as @greengrass can do the credentials changes.
greengrass
Thank-you both.
It is a good suggestion and I appreciate it.
I am not confident about changing the routers over. In case I am unable to connect again.
That may sound daft but I am talking from experience Smiley
So, I will leave it as it is for now.
greengrass
The second Openreach engineer arrived yesterday.
When he got out of the van he thought he was just there to connect the cable that the groundworkers installed to the outside grey box.
I was not surprised and expected this to happen.
I informed him that there was no ONT inside the property from the previous engineer and that the cable had been cable clipped to the skirting board.
This engineer said that normally the ONT would be fitted inside the property on the outside wall and an extension lead used after that. My ONT is fitted about 2.7 meters inside the property.
He also said that he would not put the ONT quite where the original Engineer had said he would. Apparently this Engineer would be fitting a 2.0 not the 1.0 ONT. So he had to take out 2 cable clips from the skirting board and noticed a kink in the cable.
I must admit I found the whole process rather stressfull being told different things by different Engineers and Groundworkers, not sure what or who to believe.
It is working, I am on FF145.
On my laptop with an Ookala speed test I get about 52 download and 31 upload. I was getting about 7 download and 0.75 upload on BB.
I do not use my mobile for internet but the Engineer suggested the slower than expected speed may be because it is an old laptop. I did the speedtest on my mobile and sure enough I did get 145 download and 47 upload.
One question I have, on the PN2 the blue light does not go all the way around the circle, it is at the top and bottom, is that normal?
I will try to attach a few pictures.
Fixes: 583
@greengrass
That sounds like your laptop is connecting to the 2.4ghz wifi band rather than the 5ghz band.
Does the wifi adaptor in the laptop support 5ghz ?
greengrass
Thanks for the reply.
I Googled "how do i find out if my laptop wifi adaptor supports 5ghz?"
Followed the instructions "Click on Windows/Start icon and type cmd and press Enter. 2. From within the Command Prompt Type netsh wlan show drivers and press Enter. Look for Radio types supported"
Did not find any information in that regard.
Fixes: 387
@greengrass What is your laptop make/model? How old is it?
greengrass
Thank-you.
It is an HP model 14-bs145na
Not sure when I bought it. I bought it new in I think in 2018.
Fixes: 583
@greengrass
This is what netsh wlan show drivers reported on my system
Interface name: Wi-Fi
    Driver                    : Intel(R) Wi-Fi 6 AX201 160MHz
    Vendor                    : Intel Corporation
    Provider                  : Intel
    Date                      : 06/02/2025
    Version                   : 23.120.0.3
    INF file                  : oem30.inf
    Type                      : Native Wi-Fi Driver
    Radio types supported     : 802.11b 802.11g 802.11n 802.11a 802.11ac 802.11ax
    FIPS 140 mode supported   : Yes
    802.11w Management Frame Protection supported : Yes
    Hosted network supported  : No
    Authentication and cipher supported in infrastructure mode:
                                Open             None
                                Open             WEP-40bit
                                Open             WEP-104bit
                                Open             WEP
                                WPA-Enterprise   TKIP
                                WPA-Enterprise   CCMP
                                WPA-Personal     TKIP
                                WPA-Personal     CCMP
                                WPA2-Enterprise  TKIP
                                WPA2-Enterprise  CCMP
                                WPA2-Personal    TKIP
                                WPA2-Personal    CCMP
                                Open             Vendor defined
                                WPA3-Personal    CCMP
                                Vendor defined   Vendor defined
                                WPA3-Enterprise 192 Bits GCMP-256
                                OWE              CCMP
                                WPA3-Enterprise  CCMP
    Number of supported bands : 2
                                2.4 GHz [ 0 MHz - 0 MHz]
                                5 GHz [ 0 MHz - 0 MHz]
    IHV service present       : Yes
    IHV adapter OUI           : [00 00 00], type: [00]
    IHV extensibility DLL path: C:\WINDOWS\system32\IntelIHVRouter10.dll
    IHV UI extensibility ClSID: {00000000-0000-0000-0000-000000000000}
    IHV diagnostics CLSID     : {00000000-0000-0000-0000-000000000000}
    Wireless Display Supported: Yes (Graphics Driver: Yes, Wi-Fi Driver: Yes)
The bold lines are the significant ones
'netsh wlan show interfaces' will show which band its currently connected to
There is 1 interface on the system:
    Description            : Intel(R) Wi-Fi 6 AX201 160MHz
    GUID                   : eef47b82-2ef1-447a-add9-4d6cca684a63
    Physical address       : xx:xx:xx:xx:xx:xx
    Interface type         : Primary
    State                  : connected
    SSID                   : *********
    AP BSSID               : xx:xx:xx:xx:xx:xx
    Band                   : 5 GHz
    Channel                : 56
    Connected Akm-cipher   : [ akm = 00-0f-ac:08, cipher =  00-0f-ac:04 ]
    Network type           : Infrastructure
    Radio type             : 802.11ax
    Authentication         : WPA3-Personal  (H2E)
    Cipher                 : CCMP
    Connection mode        : Auto Connect
    Receive rate (Mbps)    : 961
    Transmit rate (Mbps)   : 288
    Signal                 : 84%
    Rssi                   : -56
    Profile                : ************
    QoS MSCS Configured         : 0
    QoS Map Configured          : 0
    QoS Map Allowed by Policy   : 0
greengrass
I see thanks.
3.  Verify that 802.11a. 802.11ac, or 802.11ax are supported, if any of these are listed your device will support the 5.0Ghz Wireless spectrum. If you also see 802.11b, or 802.11n it       means your device will support both the 2.4Ghz & 5.0Ghz ranges.
4. If you do not see 802.11a, 802.11ac, or 802.11ax your device will not support the 5Ghz and will need to be upgraded in order to connect to HSCwave."
I do not seem to be able to copy the text from the cmd. But none of the above 802. are showing.
Fixes: 583
According to AI , the wifi adaptor in that is a dual band so should be able to connect to the 5ghz band on the Hub 2
The HP 14-bs145na comes equipped with a Realtek RTL8821CE-M 802.11a/b/g/n/ac (1x1) Wi-Fi adapter. This means it supports dual-band Wi-Fi (the 2.4 GHz and 5 GHz bands) and wireless networking up to the Wi-Fi 5 (802.11ac) standard.
Highlight the lines with the mouse, then right-click, that will copy the lines to the clipboard
greengrass
Actually, scrolling down I see that "radio types supported 802.11n 802.11g 802.11b"
greengrass
I am able to cut or copy and paste without a problem but not in my cmd.
It certainly does not show these I copied from your post.
"   Number of supported bands : 2
                                5 GHz [ 0 MHz - 0 MHz]"
"    Band                   : 5 GHz"
Fixes: 387
Something looks strange in the post above, @greengrass , if that is copied from your own machine specs.
