Joomla-based site give server ( 500 ) errors since earlier today
- Everything else
- Joomla-based site give server ( 500 ) errors since...
16-03-2010 12:09 AM
Re: Joomla-based site give server ( 500 ) errors since earlier today
16-03-2010 12:34 AM
16-03-2010 7:43 AM
I did try playing with the .htaccess last night with no luck., I also uploaded a simple test.php file to the root and could not access that either???!!!
Bit fed fed-up as I moved my Joomla site from the PAYH server cos of all the hassle and now I'm here, stuck again!
Andrew 😞
16-03-2010 9:00 AM
#Options +FollowSymLinks
#RewriteRule (.*) gtsagedev/index.php
No problems with permissions
Only problem now is with sending mail from the contacts page. The Joomla Mail settings in Global Configuration are
Mailer PHP Mail function
Mail from (my plus.com)
From Name (my name)
Sendmail Path /usr/sbin/sendmail
SMTP Authentication No
SMTP Security
SMTP Port 25
SMTP Username (blank)
SMTP Password (blank)
SMTP Host localhost
But no emails are being sent. Will experiment and report back!
16-03-2010 12:51 PM
16-03-2010 3:29 PM
I'll try when I get home because although I can FTP to the PAYH and HTTP servers from work, I can't access the CCGI one 😞
Andrew
16-03-2010 3:45 PM
17-03-2010 8:35 AM
Quote from: Gabe #Options +FollowSymLinks
I couldn't find the second line you mentioned, but removing
has fixed the problem, now I need to hack through the .htaccess again to hide the joomla install directory again, I know there is plenty of help out there but it takes me ages to get it working...
Bob
Quote from: Bob You'll need to be connected to our netwok in order to access the CGI platform.
I didn't quite understand this comment, was it for me? Of course I'll need to be connected to your network????
Andrew
17-03-2010 8:58 AM
Quote from: rekabuk Gabe,
That's not me. Thanks gandb
Quote now I need to hack through the .htaccess again to hide the joomla install directory again, I know there is plenty of help out there but it takes me ages to get it working...
The rewrite <a href="http://community.plus.net/forum/index.php/topic,84267.16.html">here</a> might help.
Gabe
18-03-2010 3:44 PM
Quote from: rekabuk I didn't quite understand this comment, was it for me? Of course I'll need to be connected to your network????
It was a reply to your post here. Some people don't realise that they'll not be able to FTP to the CGI servers from outside of the Plusnet network.
- Everything else
