Internet causing a TV problem
- Everything else
- Internet causing a TV problem
15-03-2019 12:20 PM
Firstly, unsure which forum is the right one for this. Please be patient with me.
I wonder if someone can help. Two Smart TV’s, different makes in different rooms. Both have started cutting out to standby, resting for about 5 seconds, and coming back up. Only on live TV through the house aerial. This does not happen on internet Smart functions such as Catch Up or Netflix. However when I turn off my router, live TV works fine and no longer cuts out. This problem is purely driven by whether the internet is on or not. Speedtest gives a down load speed of 7.02 Mbps. I have reinstalled one of the TV’s from factory settings to no avail. As an aside, I have an ordinary non Smart TV in the bedroom – this works fine. Can someone help please, it’s driving us crazy!
Re: Internet causing a TV problem
15-03-2019 1:57 PM
Hi @BertieBassett,
I'm sorry to hear that you're experiencing these issues with your Smart TVs. I'm afraid that, as long as the broadband service itself is up and running without fault, we can't support any 3rd party systems that are in place. Perhaps some of the other community members can help provide some help with this query, but otherwise I would recommend contacting the manufacturers of the TV's to see if this is something they may be able to support with.
15-03-2019 2:05 PM
This topic has been moved from ADSL Broadband to Everything Else.
Customer and Forum Moderator. Windows 10 Firefox 86.0 (64-bit)
15-03-2019 2:19 PM
Okay, I'll have a crack of solving the mysterious, yet oddly bizarre, issue then.....
If you disconnect the TV (via the TV settings) from the router and watch live TV, do they both still drop?
I kinda leaning to the fact that during live (aerial) TV watching they both could be 'phoning home' for updates - I can't answer why they're both dropping though, even if the wifi signal was poor
Also, if you're using them with the apps, there's a good chance the TV software stops auto updates so you don't drop the app you're using.
Have you also tried turning off auto updates on both TV's?
15-03-2019 3:15 PM
Thanks AJ. Yes I understand. If it was one TV causing the problem I would think it was the device itself. However, two TV's of different makes behaving in the same way suggests something a little more sinister? I understand it's not Plusnet's problem if the connection is fine - but I wondered if it was possible to download malware or a bug on to a TV? My laptop is covered by Norton but presumably nothing safeguards a Smart T.V? I would hate to junk two T.V's 'cos they had been corrupted? Just wondering......Any thoughts will be useful from you P.C. wizards out there.
15-03-2019 3:58 PM
Thanks DD. I'll have a go. They don't drop once the TV is disconnected from the router. WiFi signal is great and all the Smart features work. Just terrestrial when the routers on. Strangely strange.
15-03-2019 4:12 PM
That's why I'm inching ever closer towards the TVs updating, or am I.....
Our main one, by default of the manufacturer, wants to check between 2-3am!! Now I'm not saying your router isn't the actual cause here, we (as in us that give vast sums to PN) need to rule our gear out as the fault.
I can't get to the other TV to check as it's in my sons bedroom
Now I'm using the Plusnet Hub One, and interestingly I too am witnessing some oddities around my (main) TV and my router.
For example:
02:49:11, 10 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: WiFi registration failed
02:49:11, 10 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client disassociated
03:00:11, 10 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client associated
03:34:11, 10 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: WiFi registration failed
03:34:11, 10 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client disassociated
14:02:28, 10 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client associated
17:27:20, 10 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client disassociated
17:27:20, 10 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client associated
01:19:12, 11 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: WiFi registration failed
01:19:12, 11 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client disassociated
03:00:11, 11 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client associated
03:34:12, 11 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: WiFi registration failed
03:34:12, 11 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client disassociated
03:58:07, 11 Mar. PPP LCP Send Termination Request [User request]
03:59:15, 11 Mar. System up, firmware version: 4.7.5.1.83.8.263
12:25:46, 11 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client associated
23:59:02, 12 Mar. System up, firmware version: 4.7.5.1.83.8.263
03:00:11, 12 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client disassociated
03:00:11, 12 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client associated
03:31:14, 12 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: WiFi registration failed
03:31:14, 12 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client disassociated
12:45:47, 12 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client associated
23:59:13, 12 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client associated
02:01:09, 13 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: WiFi registration failed
02:01:09, 13 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client disassociated
02:27:27, 13 Mar. PPP LCP Send Termination Request [User request]
03:00:13, 13 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client associated
03:31:09, 13 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: WiFi registration failed
03:31:09, 13 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client disassociated
12:24:04, 13 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client associated
02:31:10, 14 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: WiFi registration failed
02:31:10, 14 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client disassociated
03:00:09, 14 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client associated
03:31:10, 14 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: WiFi registration failed
03:31:10, 14 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client disassociated
12:49:51, 14 Mar. System up, firmware version: 4.7.5.1.83.8.263
12:48:50, 14 Mar. PPP LCP Send Termination Request [User request]
13:04:25, 14 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client associated
On BobP's advice, the PNH1 was factory reset
01:54:01, 15 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client associated
02:37:49, 15 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: WiFi registration failed
02:37:49, 15 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client disassociated
03:00:12, 15 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client associated
03:37:49, 15 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: WiFi registration failed
03:37:49, 15 Mar. ath00: STA 70:54:b4:<redacted> IEEE 802.11: Client disassociated
This is all for my TV!!
Rule this out and it can only be that
15-03-2019 8:21 PM
Wow - that's impressive - I think....Anyway, everything seems to gone back to normal for no reason whatsoever. Both TV's are now working properly again. Absolutely no exaggeration on my part. One minute they are behaving exactly as I described above, the next minute they are fine. What worries me a little is, if I hadn't got two televisions, different makes, different rooms, behaving in exactly the same way, I might have blamed the TV out of hand.( and ultimately scrapped it?) I wonder if this happens? As far as I can see, it's near impossible for it to have been the TV's, without input from the WiFi. Either interfering or downloading something into the "valves and tubes". Strangely strange but oddly normal. Big brother, Twilight Zone etc etc. Thanks for your help - probably be back tomorrow when it rebels again.
15-03-2019 8:38 PM
Nah, more of a pain than impressive!!
Hmm, chalk it up as one of those mysteries I suppose...
I'll admit it, the chances of both TVs being seeing the same issue is, well, probably, is quite remarkable - did you buy a lottery ticket as I'd of thought you'd be more likely to win on that rather than see what you saw.
No problemo, I'm sure I'll be lurkin' somewhere on here
If it does this Twilight Zone do do do do thingymebob again, try one TV connected by WiFi and the other not connected. If both still turn off, unless a neighbour is messing with their remote at your window, then you might need spiritual help!!
16-03-2019 9:51 AM
Just out of curiosity are you close to a 4g transmitter, I had a similar problem and eventually got a 4g filter, fitted as instructed and all has bee fine since. Just thought that maybe another avenue for you to investigate.
16-03-2019 10:31 AM
Unsure - I'll check. Thanks.
- Everything else
