Installing SMF Mods
- Everything else
- Installing SMF Mods
Installing SMF Mods
18-03-2009 11:15 PM
Hi All
I am Getting Errors wen trying to install SMF Mods, wen I try installing Aeva (YouTube/video/audio auto-embedder) I get:
FTP Information Required
Some of the files the package manager needs to modify are not writable. This needs to be changed by logging into FTP and using it to chmod or create the files and folders. Your FTP information may be temporarily cached for proper operation of the package manager.
550 http://dyslexia.plushost.co.uk/forum: No such file or directory
See screen shot
See screen shot
Message 1 of 7
(1,407 Views)
6 REPLIES 6
Re: Installing SMF Mods
19-03-2009 8:40 AM
I have just checked all the files via FTP and they are all correct in their chmod settings (775) which are writeable by you the owner. I honestly haven't a clue It installed all ok yesterday evertually the problem I had was related to the dumping of your old database.
As I said I haven't got a clue and have never come across this error before, I spent several hours installing the forum for you, I think you will have to search around on the SMF community boards.
If I get some time I will have a nose for you
Message 2 of 7
(315 Views)
19-03-2009 8:50 AM
I just checked your forum error logs and I am not sure but I think this may have a bearing.
SAFE MODE Restriction in effect
Message 3 of 7
(315 Views)
19-03-2009 2:49 PM
I found another few minutes to have another look around. and installed the mod for you.
if that screen comes up again for the path Just have : httpdocs/forum
and that should work
thanks would be nice .. thats about 4 hours I have put in on your forum deserves a thanks at least
Message 4 of 7
(315 Views)
20-03-2009 4:23 PM
Quote from: gordo deserves a thanks at least
As I sed in the PM to you I owe you a drink or 4. Many thanks for all your hard work.
Message 5 of 7
(315 Views)
20-03-2009 4:45 PM
I'll take the 4 hahahaha. thats OK thanks is more than enough. is everything working well ?
Message 6 of 7
(315 Views)
20-03-2009 5:08 PM
Quote from: gordo is everything working well ?
Yep, but I am missing a member = you.
Message 7 of 7
(315 Views)
