IP address is assigned a Postcode in wrong town
- Everything else
- IP address is assigned a Postcode in wrong town
2 weeks ago
Re: IP address is assigned a Postcode in wrong town
2 weeks ago
@daiwatt46664 Do not worry where they 'think' you are - unless it is outside the UK. Geolocation is a very imprecise art - Google maps for instance currently thinks I'm in Wiltshire, which is quite a distance from Sheffield.
2 weeks ago
Post codes are not assigned to a Public IP by the ISP.
Many mobile devices have Apple Relay enabled, this like any VPN or Proxy will give misleading location results.
What do you see with : https://whatismyipaddress.com/
before considering the location, verify the Public IP displayed matches the Public IP shown in your Hub / Router.
2 weeks ago
@PhilipHeyes I've tried your link and It reckons my location is over 200 Miles north of where I live.....
2 weeks ago - last edited 2 weeks ago
As I said IP location is very 'approximate' my laptop says I'm in Wiltshire (Tewksbury area), although both iPad and iPhone correctly have me in SW Sheffield.
@PhilipHeyes link puts me in Manchester, where my ISP's northern data centre is.
2 weeks ago
Thanks for all the replies.
https://whatismyipaddress.com/ --> London
Sites think I'm at CA26 3SD (Gateshead) - where is this coming from if not ISP?
I'm in Hay-on-Wye (Powys)
Have tried configuring location setting and addresses within Google ; have cleared caches.
so not sure how to correct this 'misalignment'
@daiwatt46664 See previous comments - it depends which IP location databases the sites use, and even those databases are quite often wrong.
You, nor anyone else, can correct this anomaly.
2 weeks ago
What does https://nordvpn.com/ip-lookup/ say about your location?
Probably something different. Puts me in Oxfordshire, which is a new one, and still wrong.
2 weeks ago
@AyToZed I've tried your link and It reckons my location is over 200 Miles south of where I live.....
a week ago
Out of interest. Are you on Plusnet allocated IP? If so, are you on a (legacy) fixed IP?
a week ago
@AyToZed For over 20 years I’ve been a Plusnet customer allocated a fixed IP address.
For info : every different location check I’ve tried shows me in a different location, nowhere near where I live…….
a week ago
Thanks for the replies.
https://nordvpn.com/ip-lookup/ puts me in Newport NP20, which is different again - that's 4 different locations including my real one.
No idea about my 'legacy' status
This seems all over the place and impossible to configure on Chrome, which seems to ignore my account's address.
Anyway thatnks for the help, it appears to be uncontrollable behaviour.
- Everything else
