IP Address Wrongly Identied as US Based - Issues with disney +
Fixes: 369
Re: My IP resolves to US, not UK.
@sd77 You will, IP''s are sticky, and short power off's will most likely return the same IP.
dave
Fixes: 18
Netflix should be fixed now. Waiting for an ETA on Disney+ and ITVX.
Dave Tomlinson
Plusnet Technology
StevenPatterson
Hi Dave, thanks for looking into this.
I have had the same issues and tried rebooting the router to get a new IP block but with no luck. My geoblocking issue is with Discovery+, has there been any contact made with them about using the correct IP registries ?
Shaunwood
Thank you. My Netflix is showing uk content again.
ItsAlwaysDns
Netflix is fixed, unfortunately, Paramount+ is now broken…. Sad
Jammy121
I’ve got the same issue with paramount plus and my FAST speed checker still think I’m in the USA. I’ve only been a Plusnet customer for a month so find this all very frustrating. Reading back I can see that some people think it’s the fault of Netflix etc but I’ve never had a problem with them for years yet I’ve been with plusnet for a month and this happens. When it’s happening on Netflix, on Disney, on itv, on paramount then it’s something that needs sorting quickly.
Fixes: 369
@Jammy121 It is currently under review - see post #29.
Jammy121
I saw. But that could mean anything. It might be resolved tomorrow or the day after or a week after.
Fixes: 369
It will take as long as it takes - when you are dealing with organisations such as Disney/Netflix, you are dealing with disjointed entities.
Gippert
Hi dave I have the same issue on netflix and disney + my IP starts with 150
Jammy121
I’d like to hear someone from plusnet give an estimate. It’s good customer service!
Fixes: 369
when they know, they will let us know - guesstimates don't really help anyone, and some treat such as gospel, and moan when they are missed.
Jammy121
I’ll call them in the morning and post what they say. Streaming services not working for customers is poor and as the ISP it’s plusnets fault as far as I’m concerned especially when it’s multiple streaming services for multiple customers.
Fixes: 369
Best of luck.
Jammy121
My Nintendo switch also thinks I’m in the US. This is just a complete joke
