I can't figure this out. Two domains, both show the same
- Everything else
- I can't figure this out. Two domains, both show th...
Re: I can't figure this out. Two domains, both show the same
12-09-2007 12:35 PM
12-09-2007 12:55 PM
Ok, now you know what we're talking about, this is exactly what i want to do.
The domain WITHOUT the hypen is site 1 and uses .html file extensions.
The domain WITH the hypen is site 2 and uses .php as the extension to each page.
What exactly do I need to do?
12-09-2007 1:36 PM
The second site will need pointing at the cgi space, you can then upload to this via ccgi.plus.net, however as previously advised this can only be from a PN connection. If you want me to sort out domain2 so it points to the ccgi servers just reply here stating this and I'll arrange the domain records for you.
12-09-2007 1:56 PM
My concern is that domain1 (hosted currently on the homepage servers) is not working also.
If you could make the site (with the hyphen) pointed at the cgi server then that would be great.
I assume then that I can use Filezilla but only if I am from a plus net connection?
Thanks again.
12-09-2007 1:59 PM
I'll also go point domain2 at the cgi servers, you can use filezilla no problem, that's actually what I use myself.
12-09-2007 2:02 PM
So, even for the CGI server, its my normal username and password?
12-09-2007 2:05 PM
I've sorted the domain records now, as before I'd wait at least 4 hours before checking.
www.domain1.co.uk will point to www.username.plus.com
www.domain2.co.uk and domain2.co.uk will point to ccgi.username.plus.com
I'll check before I leave tonight for you, and if they haven't updated by then I'll check in the morning too.
12-09-2007 2:21 PM
12-09-2007 4:46 PM
Cant see it though.
Any ideas?
12-09-2007 4:51 PM
12-09-2007 4:59 PM
12-09-2007 5:02 PM
If so then as I said earlier you will just need to wait for DNS to update before trying to visit www.domain2.co.uk
12-09-2007 5:03 PM
12-09-2007 5:31 PM
I've just uploaded site two but I can only view it from a plus net connection.
I also had to change all the file attributes for each page.
Also, it is outside of the cgi folder.
If I view it at my location, I get redirected.
12-09-2007 5:33 PM
- Everything else
