Help with epp code
Harbourart
Help with epp code
Hi there.
I need to speak to someone who can handle a domain transfer away from Plusnet to ifastnet.
The domain in question is harbourart.co.uk and i am getting conflicting information when searching the Internet.
The original service provider was freenetname.
Please can someone sort this for me?
16 REPLIES 16
RPMozley
Seasoned Pro
Fixes: 18
Re: Help with epp code
For all .uk domains you need a IPSTAG for transferring a domain.
That's RPM to you!!
Harbourart
OK thanks for the reply, but where would I get this from?
Fixes: 388
A PN staff member will pick this up and send you a PM requesting details.
Harbourart
Thank you.
Fixes: 585
You get it from your new registrar. You then provide that to Plusnet who change the tag on your domain.
Looking at the ifastnet website , they are US based and so are probably more familar with transferring non-uk domains which require an EPP code.
Harbourart
I have contacted ifastnet who asked for the epp code?
Also the contact centre I use is in Newcastle UK.
Fixes: 585
I'm sorry but they're wrong!. An EPP code is only for a non-uk domain. uk domains are handled through Nominet and the transfer procedure is via a change to the IPSTAG. Its not possible to issue an EPP code for a .uk domain
Harbourart
OK thank you I will get back on to them and ask again.
Fixes: 585
Is there a reason you're going with ifastnet ?
Harbourart
I already have two domains with them, easier to update all in one place.
Fixes: 585
Ok
willcutforth
Fixes: 113
@Harbourart let me know when you have the IPStag Smiley
 Will Cutforth
Harbourart
Thanks Will I will.
Harbourart
Hi Will I have sent you the IPStag in a PM
