Freenetname. Cannot send emails. But can receive
chuckles
Can anyone help ?
I have a freenetname domain and email. Have done for 20 years.
Few weeks back I suddenly couldn't send emails via outlook and mobile.
I can get them, but not send.
Ii get an error message 554... see attached...
HELP ..................
17 REPLIES 17
plusnettony
Fixes: 78
Re: Freenetname. Cannot send emails. But can receive
I'll take a closer look at this when I get into the office.
 Tony T
chuckles
Have you found a Solution ?? This is seriously affecting my business !!
LexLex2020
Fixes: 12
Hi @chuckles
I know this is the basic thing to try but have you attempted to remove and add back in your freenetname account into outlook?
What outgoing and incoming server are you using for outlook?
Thanks,
Lex
Lex Keehner
chuckles
Yup., did all that.
Incoming is 110 and have tried both 587 and 25 on outgoing.
I keep getting a   "  554 avasout-peh 003  smtp ESMTP server not available. "  message
I've also done a spam check thing on my IP address etc and all clear.,
chuckles
Has ANYONE found a solution to this ?Huh
Fixes: 585
@chuckles unfortunately neither your first post or the latest ones give the full details of the error message
Can you try the email diagnostics from here https://community.plus.net/t5/Email/Diagnosing-email-server-connectivity-issues-the-guide/m-p/200795... please, particularly the SMTP one and report the results
plusnettony
Fixes: 78
Can you try webmail - does this do similar ?
 Tony T
chuckles
Webmail works., but I need is to go through Outlook .
Fixes: 251
Have you followed the advice in post #7?
See the diagnostic link below.
chuckles
Yes. The error I am getting is this..........
Send test e-mail message: Your outgoing (SMTP) e-mail server has reported an internal error. If you continue to receive this message, contact your server administrator or Internet service provider (ISP).  The server responded: 554 avasout-ptp-003 smtp ESMTP server not available
Fixes: 251
That’s not what was requested.  Please run the email server connection diagnostics using the link below.
That will test your ability to connect to the mail services without confusing messages from an email client which do not tell you what’s really wrong.
chuckles
This is what I get when I run the test via powershell
* Host smtpmail.freenetname.co.uk:587 was resolved.
* IPv6: (none)
* IPv4: 212.159.8.233, 212.159.9.233
* Trying 212.159.8.233:587...
* Connected to smtpmail.freenetname.co.uk (212.159.8.233) port 587
< 554 avasout-peh-003 smtp ESMTP server not available (blacklisted by local policy)
* Got unexpected smtp-server response: 554
* closing connection #0
curl: (8) Got unexpected smtp-server response: 554
Fixes: 251
Great - that’s unambiguous.
I will see what I can find out.
Fixes: 251
@chuckles
Really useful reference diagnostic - thank you.
I will escalate this.
