Forum Backup
- Everything else
- Forum Backup
Forum Backup
20-04-2009 11:03 AM
Thanks for any advice!
Re: Forum Backup
20-04-2009 12:46 PM
Thats about all I know of what to do.
When I had a little more space on my server, I had another forum Identical hidden from public view, then every so often I would back up the data-base from the live forum and dump it into the hidden one. If problems occured that forced a re-install I simply juggled the folder names to make the hidden on the live one, nobody has ever noticed a thing as the urls were exactly the same.
Re: Forum Backup
20-04-2009 1:20 PM
I notice there is a Backup Manager in Parallels Plesk Control Panel 8.6 which allows one to Upload Files to Local Repository as well as Schedule Backups. That sounds pretty good, doesn't it? Do you think that should do the trick?
PS: What would I use as Local Repository?
Re: Forum Backup
20-04-2009 2:56 PM
sorry can't be more help
Re: Forum Backup
20-04-2009 5:00 PM
Or perhaps someone else might know?
Re: Forum Backup
20-04-2009 7:47 PM
Re: Forum Backup
21-04-2009 9:57 AM
Re: Forum Backup
21-04-2009 3:49 PM
Backup and restore a Web site with its databases and applications,
when you use the back up feature. someone from Tech Support can surely answer this better than me, I think ? hahahaha
Personally I would still go the way I have, just in case, but that comes from hardly using Plesk. If you really get stuck or have any difficulties PM me mate. using SMF to back up and download is quite painless, as is PHPmyadmin, dumping a file into a DB is easy with a little file called "BigDump" have done many times.
Re: Forum Backup
21-04-2009 8:10 PM
Re: Forum Backup
22-04-2009 3:43 AM
- Save the table structure.
- Save the table data. (the important stuff.)
- Compress the file with gzip.
Then clik Download
Save the file to a folder with a name that you can remember on your computer, you can Backup daily or weekly.
Me I keep the first one, then once a month I keep the file, it is up to you how long you keep the file for on your computer!
[Edit]
You may want to Backup the full of your forum files from httpdocs if you have SMF Mods installed, or you have modified your forum like I have, with the help of gordo and the SMF Community forum, there is a link to my forum on my Signature. Good look with your forum.
gordo Thank you for all your help your the best
Re: Forum Backup
22-04-2009 9:14 AM
I've done that but it does not look like much! Are you sure absolutely everything is in there? Which one is the one that has all the posts in? Is it the data one?
Re: Forum Backup
22-04-2009 1:24 PM
Re: Forum Backup
22-04-2009 6:21 PM
Let me know,mate and I can always check things for you, if you give me access to the forum admin, and then you can delte my account. Understand if you would rather thats if you still are unsure (believe it is right)
Re: Forum Backup
23-04-2009 2:48 PM
I've got a zipped file which looks like -------_-complete_2009-04-22.sql.gz, so pretty much what you have too!
I really appreciate your answers, many thanks again!
In a rush...
Re: Forum Backup
23-04-2009 11:43 PM
