Fixed IPAddress with host name showing most of my name! Change to Anonymised Hostname Request
Kit1
I have a fixed IP Address which I require, and need to retain.  When I joined Plusnet I was unaware that my username / hostname would be based on my initials and surname.  However, anyone using reverse DNS sites (of which there are many) can very easily see that the IP Address is associated with my username from which it is easy to work out my full name.
I understand that it is possible to have my hostname anonymised so it would be seen via rDNS as
myIPAddress@plusdsl.net
Please would a Plusnet representative confirm that this is possible and arrange for it to be carried out.  I assume that there would be no break in internet provision.
Many thanks!
6 REPLIES 6
Fixes: 528
Re: Fixed IPAddress with host name showing most of my name! Change to Anonymised Hostname Request
@Kit1 it is possible and i'm sure one of the plusnet help team staff will be along shortly to arrange it.
though its not quite as you believed, it will appear as <ip address>.plus.com
Kit1
Many thanks for the response and pleased it can be done!
willcutforth
Fixes: 113
Hey there @Kit1 it took me some time but I returned from my adventures. Please can you reply to https://www.plus.net/wizard/?p=view_question&id=238550027 and then I will sort it for you?
 Will Cutforth
S12345
I have just got off the phone with Plusnet who categorically state that it is not possible to change my hostname. I am now confused as to the correct answer. I have to say the person on the phone couldn't really give me a detailed explanation as to why it was not possible, just that it is not.
Fixes: 334
@S12345 You were given wrong information - hopefully one of the Help team will pick this up and raise a ticket to achieve what you want.
MatthewWheeler
Fixes: 503
Hi @S12345
I've raised a ticket on your account regarding this
If you can respond to it we'll get that picked up for you
After the 3rd of November I will have a limited presence here as I have moved to a new role
 Matthew Wheeler
