Fixed IP option missing
gazp
Hi
I’ve previously paid for a Fixed IP but when I look in Add Ons no there’s no mention of it - is anyone from PN able to confirm my IP is fixed and if not re-enable it on my account?
Many thanks
Tags (1)
5 REPLIES 5
Fixes: 388
Re: Fixed IP option missing
If you have paid for a fixed IP, you will still have it. It is, however, now not an option for anyone without one.
Fixes: 480
Moderator's note:
Thread moved from Broadband to Everything Else
@gazp
you can check if you still have a static IP Address by using windows command nslookup for your broadband IP Add
A dynamic IP will provide this result for IP 83.216.128.100
nslookup 83.216.128.100
Server:  UnKnown
Address:  192.168.10.1
Address:  83.216.128.100
Anything else will be static.
HTH
EDIT: Try this site https://www.ipchicken.com/ look at "Name address"
Fixes: 1,495
I'm not staff, but can confirm your IP is fixed.
gazp
Thanks all, appreciate the help and tips
