File Manager Pro - Restore Failure
allied
Website has been working well for a few days but now home page seems to be corrupt so go to restore all and although it says 'Congratulations' has not done it and History shows most folders as 'Failed'.
8 REPLIES 8
bobpullen
Fixes: 306
Re: File Manager Pro - Restore Failure
File Restore should give you the option to choose from multiple snapshots, have you tried a few of them?
allied
Yes tried to restore different backups a number of times. The history shows cgi-bin, secure and .htaccess 'success' but all others as 'failed'.
bobpullen
Fixes: 306
We could get Hostopia to take a look and see if they can restore things for you, but it would probably be easier and quicker for you to restore things yourself from a local backup.
allied
Could Hostopia please restore to Midday on Wednesday 21st please?
bobpullen
Fixes: 306
I've tried restoring your logs, private and public folders using a 55 hour old snapshot (which is a bit later in the day last Wednesday). The attached confirmation message suggests it's been successful?
allied
Bob,
Thank you for the notification however if you check the history you'll see it failed on many of the folders / files/
bobpullen
Fixes: 306
Ah, I see. I overlooked that link.
I've raised a ticket with Hostopia to see if there's anything they can do from their side (ref: 3708114).
bobpullen
Fixes: 306
Can you check again?
I've just heard from our suppliers and they're suggesting that they've been able to restore your files.
