Fairly confused
gardent
Fairly confused
Have I thought these changes through sufficiently? I have been reading many threads here and I understand things a lot better than before, but I am not yet confident enough to proceed. I posted in 'everything else' because it seems to be more than one topic. I assume someone will shift it if I'm wrong.
What we have-
1/ BT home phone on overhead cable, with old secondhand BT handset. It is hardly ever used but I prefer to keep it for the moment. We have mobile phones for occasional use.
2/ ADSL broadband from Plusnet, using a secondhand plusnet technicolour router. Usual speed is nearly 3Mb. (Its a long way to the cabinet) Our Force9 email has already been transferred to Greenby. I don't know about the free webspace.
We have recently received the same scaremongering letter from BT that has been mentioned by several people here.
I don't like hassle and I don't like firms who get you stressed out by making you ring up to do anything, but I can see I am going to have no choice.
What I think we need to do-
Arrange smallest size of full fibre from Plusnet. (Last time I checked I can't have FTTC, it has to be FTTP) Make sure they supply a newer router.
Arrange voipphone account with Voipfone or A&A. Tell them what our number is. The Plusnet account is in my husband's name so this will presumably also have to be in his name.
Buy new simple corded phone and adapter. (from voipfone? if so, when?)
Questions-
How much of this can be organised online?
What is the right procedure/jargon for changing our old broadband contract (no expiry date) to FTTP?
Can I continue to ignore BTs letter or is the 30 day limit 'to upgrade' mentioned at the end, relevant to something they need telling?
How quickly will 'they' fit the fibre and what happens if there are holdups or problems? The broadband availability checker says 'single dwelling unit OH feed with no anticipated issues' which sounds promising. The nearest pole (carrying electric cable as well) in next door's hedge only serves us two and the other house(which has never had broadband) is for sale. They cannot bring the fibre through our downstairs wall which is three foot thick rubble stone, which blocks wifi in some areas. Upstairs is brick. (The current phoneline comes through a wooden window frame but the windows are due to be replaced) I have no idea where to tell them to put the CSP/ONT. The spare bedroom would probably give best wifi coverage and I could arrange an extension cable as a temporary power socket. Unlike master socket to router, am I right that the ONT to router is ethernet? who provides that cable? How long can it be? If this works, the ethernet cables to our current PCs will need rerouting. Can the new router be tested without the PCs attached or will we have to move the cables in advance, despite not knowing if the engineer will agree to the suggested ONT location?
Have I missed anything?
11 REPLIES 11
Fixes: 108
Re: Fairly confused
@gardent
Full fibre is available to you and can be ordered online. FF74 is the slowest speed available. It requires a new contract. Timing depends on how busy OR are.
It may be possible to get an internal CSP and ONT in the upstairs room. Is it in the same side of the house as the overhead cable. The router does connect via ethernet cable so can be anywhere you're happy to run cable. A power extension would do short term until you can sort something out more permanent for power.
I've attached two pictures. The first shows an upstairs install with an internat CSP. The second is in the loft where the home owner did a bit of prep which the engineer was more than happy to use. Both were from O/H feeds.
All you can do is think of the possibilities and talk to the engineer on the day. Also have a look at
https://www.openreach.com/help-and-support/full-fibre-broadband-installation-checklist#accordion-b43...
Do nothing with your phone until you have Full Fibre installed and running. You then have 30 days to port the number to your chosen VOIP provider. As you don't make many outgoing calls A&A could be a good choice. One ot their options is to send incoming calls to VoiceMail, a copy of which then gets sent to you by email.
https://www.aa.net.uk/voice-and-mobile/voip-information/
Fixes: 470
Re: Fairly confused
@gardent
All of it.
Sign up for Full Fibre with Plusnet. They will inform BT that you are leaving. Don’t inform BT because if they cancel your phone it will cease the Plusnet service.
Providing you sign up with Plusnet soon you should be OK. If you leave it BT will take over your current broadband connection, which will automatically close your Plusnet account.
That depends on how busy Openreach are in your area. You will not know until you sign up for the upgrade.
Yes, use Cat5e Ethernet cable. The upgrade will come with a  new router with a 1m long one, any longer you have to provide yourself. Maximum length 100m.
You must not port your telephone number to a VoIP provider until you have confirmation that your Full Fibre installation is complete. You then have 30 days before the number is lost. If you do this in the wrong order both your BT and Plusnet services will be ceased.
gardent
Re: Fairly confused
Thank you @bmc
The overhead cable is not on the same wall but it is only round one corner. I assume the new cable will be sufficiently armoured against the pebbledash that it can cope with that.
In your second picture what is the narrow box to the right of the ONT?
The openreach page you linked to says 'the engineer will connect your main device to the new router' so it looks like at least one pc does need its ethernet rerouting in advance.
If I end up after installation day with the new fibre in one side of the house and the old phone line at the other side, when will the phone actually stop working? Not until the voip company request the number sounds unlikely but possible!
@Baldrick1
Thank you. It sounds like I had better get on to ordering fibre as soon as possible.
Reading this forum one becomes aware of a worrying number of things that can go wrong. If anything happens during the number porting when the phone is off there will be problems. No one would wait 40 minutes to get through to a helpline on a pay as you go mobile!
Fixes: 108
Re: Fairly confused
@gardent
Is the spare bedroom in line of sight to the pole? If not, the engineer might, or might not, be willing to run the fibre cable "round the corner" of the house. It doesn't bend too well (unlike copper). You really need to think of all possibilities for the ONT. Then, on the day you discuss it with the engineer to agree what to do. It can be the dark art of what's desirable against what's possible.
In both pictures the box to the right is a CSP. The dark grey rectangular one is actually an external CSP - I assume it got used as the loft was not in use other than for storage. You can just see an ethernet cable disappearing out of sight down to the kitchen where the router is.
I wouldn't run any new ethernet cabling until after the install just in case the ONT can't go where you want. You have options short term. Does you phone support WiFi. If so, simply use that to confirm the FF is working. Secondly, you could buy a long ethernet cable to do the job. Lastly, you could simply "move" a PC for a short period of time to confirm things.
Note that the new router will have a different WiFi SSID and password. Usually the advice is to go into the Admin page and change these to what you already use - saves changing all other devices.
markhawkin
Aspiring Champion
Fixes: 20
Re: Fairly confused
@gardent
The advice above is on the right track.
You may well find that the Plusnet 150Mb/s service is cheaper than slower services that are available.
I've not used them but I understand that for a "landline" that you regularly use, Voipfone is a good choice.
You may be able to get this set up and working on a temporary number before your full fibre is installed then port your current landline numbers.
You will need some form of VoIP adaptor to make your existing phones work or get a new VoIP phone (perhaps DECT cordless).
gardent
Re: Fairly confused
@bmc
Thank you for your further comments. There looks like a lot of wait and see involved but it appears Openreach shouldn't have any problem fitting it in one visit, which is good.
@markhawkin
Lack of hassle is more important than lack of cost so I would probably avoid the temporary number idea, but I will bear it in mind. I know I need a new phone - apparently one this old might try to work but wouldn't be able to ring so there is no point trying it.
Next problem:-
If I change to a full fibre contract before the free webspace is transferred to Greenby then we will lose the webpages won't we? This wouldn't be critical but I thought they were supposed to have been done by now. They are still there at www.username.force9.co.uk but logging in to Greenby and going to web hosting shows nothing at all. (except the active suspended and cancelled tabs) Does anyone know what the current situation is with these?
Fixes: 108
Re: Fairly confused
@gardent
If you stay with PN for Full Fibre then there should be no problems with your webspace - you'd still be a PN customer.
mike600
Re: Fairly confused
@gardent "Lack of hassle is more important than lack of cost"
If that's the case, why are you going down this route versus the EE automatic migration?
I know many on here advocate the A&A route, but it is not always plain sailing, especially if you're not technically minded.
If it's simplicity and lack of hassle you are after, then I would suggest thinking twice about the journey on which you are about to embark.
markhawkin
Aspiring Champion
Fixes: 20
Re: Fairly confused
@mike600 and @gardent
I don't think (sadly) there is a "hassle free" solution.
The EE migration is arguably best if the "landline" is more valuable than anything else.
If keeping the Plusnet email and webspace going is important then probably the third party VoIP solution is worth considering.
I suggested a temporary number for VoIP as this is what I did.
It allowed the VoIP to be in, tested and working prior to the Plusnet fibre install and the (working) day after the Plusnet fibre install the landline ported.
I primarily have the landline for communication with relatives and they never noticed the change!
gardent
Re: Fairly confused
@bmc
That is good. The site could do with a bit of revision, but I don't think either of us happen to have an ftp program at present, unless Windows10 has it's own.
We have revised the internal ideas to something more practical, with less potential for problems. (Having remembered that the ground is much nearer the roof where the overhead cables come down to the house.)
@mike600 and @markhawkin
The EE automatic route is surely for Plusnet phone accounts not BT phone accounts. I think that would also mean having a lengthy contract, rather than something that can be easily ceased if we decide we really didn't need to keep the 'landline' after all.
We will look again at choosing a voip provider once the full fibre has been ordered from Plusnet.
Thank you all for the advice so far.
Fixes: 108
Re: Fairly confused
@gardent
If your choice is Full Fibre do let us know how the install goes.
