FTP 10060 Errors
Strat
Fixes: 565
FTP 10060 Errors
I'm having ftp 10060 errors when uploading to my homepages site again.
08/05/2015 23:44:34 : FTP Connect Error, Error code = 10060
08/05/2015 23:44:55 : FTP Connect Error, Error code = 10060
08/05/2015 23:45:16 : FTP Connect Error, Error code = 10060
08/05/2015 23:45:38 : FTP Connect Timeout
Maybe Mr Pullen can take a look when he's available please Smiley
11 REPLIES 11
spraxyt
Resting Legend
Fixes: 75
Re: FTP 10060 Errors
FTP using FileZilla to theForce9 server seems intermittent. Sometimes connects (to #1) but generally times out (no error message). Also getting similar behaviour using command line FTP.
David
Strat
Fixes: 565
I double checked with FireFTP which failed.
I've been having the problem all day today.
I had it before and Bob fixed it.
It is to f9 Homepages.
spraxyt
Resting Legend
Fixes: 75
It's homepages.force9.net I'm trying too. Also tried using the IPs but get the same timeout behaviour. I had the same problem on Tuesday, but it went away after an couple of hours then.
David
spraxyt
Resting Legend
Fixes: 75
I've just tried again and it let me connect. I disconnected, then tried connecting again and it's timing out again. I wondered if the maximum number of connections supported by the cluster has been reached (stale sessions?).
David
spraxyt
Resting Legend
Fixes: 75
I've just spoken to CS. Internal system problems which Networks are working on could be affecting this. However since you've had the problem "all day" perhaps it's something different.
David
Penny
Fixes: 8
Quote from: Strat
... I can't upload to F9 homepages either : /
Going out shortly but thought I should maybe post on here as I'll need to upload something later (update to the UK Prime Ministers page).
Don't actually remember the last time there was any issue with homepages - page display is as excellent as always, just getting "connection failed (connection timed out)" (no error number/s) when trying to FTP.
Regards,
Penny.
Penny Rollo * * * joined Force9 on 17/02/98 * * * with PlusNet from 2000 onwards * * * personal website at pennymidasrollo.plus.com
Superusers are not PlusNet staff but do have a direct line of communication into the business to raise issues, concerns and feedback from the Community.
Strat
Fixes: 565
I wonder if it's related to this http://community.plus.net/forum/index.php/topic,136286.msg1195308.html#msg1195308
Penny
Fixes: 8
... just gave it one last try and has worked : /
random.
hopefully whatever the issue was, is fixed, now (or maybe it was something different from the 10060 thing).
Strat
Fixes: 565
Working for me currently. My last failure was 11:21 this morning.
We'll see how it goes.
bobpullen
Fixes: 316
I recall seeing mention of a load balancer session problem doing the rounds last week. It affects the Force9 VIP and is intermittent. I think a fix was penned in for next week at some point.
Edit: ref - 85866, looks like some interim work was actually done on Saturday to help alleviate the problem.
Strat
Fixes: 565
Cheers Bob.
