External Domain Name To Use Plusnet Webspace
- Everything else
- External Domain Name To Use Plusnet Webspace
25-09-2009 9:12 PM
Hi
I have included webhosting on my broadband package. I also have a .co.uk domain name through daily.co.uk. Is it still possible for me to be able to direct my dns to my plusnet hosting space - if so what do I need to request?
Thanks Pax
Thanks Pax
Message 1 of 7
(2,193 Views)
6 REPLIES 6
Re: External Domain Name To Use Plusnet Webspace
26-09-2009 1:41 AM
You can transfer your domain for hosting only with plusnet. this means that you will have the domain billing with Easily but the webhosting and the email for the domain will be through plusnet
http://www.plus.net/support/domains_and_dns/hosting/domainin.shtml#hostingonly
http://www.plus.net/support/domains_and_dns/hosting/hosting_allowances.shtml
the first link has got the details of of how to do this
Message 2 of 7
(252 Views)
26-09-2009 10:39 AM
Thanks! Great!
Rather than setting up neameservers to plusnet can I just modify my DNS records www 'a' record on daily to point to plusnet?
(You see I currently use googlemail to host my domain email and this works very well and I dont want to change that bit)
Thanks Pax
Thanks Pax
Message 3 of 7
(252 Views)
26-09-2009 11:59 PM
I'm afraid that 'A' record wont work because plusnet webhosting is shared hosting platform. you can try CNAME instead:
www CNAME www.username.plus.com.
there is a dot after the com
Message 4 of 7
(252 Views)
01-10-2009 11:01 AM
A CNAME won't work either for the same reason. To have a site hosted on our platform the domain needs adding to our domain control system (DCS) via the portal, and for that to work properly the nameservers on your domain will need to be set to ns1.force9.net and ns2.force9.net.
If the domain isn't in our DCS then the appropriate mappings won't be put in to our webservers so they won't know where to get the content of your site from.
Message 5 of 7
(252 Views)
13-10-2009 5:59 PM
ok - thanks for that. So could I move the nameservers and then set up my MX records via plusnet to point back to googlemail?
Message 6 of 7
(252 Views)
19-10-2009 3:48 PM
Yes, that should work fine.
Message 7 of 7
(252 Views)
- Everything else
