Excel
- Everything else
- Excel
Excel
13-07-2008 11:48 AM
Hi
I have some data I want to publish on a website that is n Excel. It's quite big and I would like users to be able to filter it.
If you publish it from Excel there seems to be a couple of drawbacks.
Is there a way round this that is easy to implement do you know?
- the page displays with a white background and is quite small.
- thepage only opens propoerly in IE.
Message 1 of 6
(1,512 Views)
5 REPLIES 5
Re: Excel
13-07-2008 1:51 PM
there used to be a Microsoft Wizard to produce a section of a web page, used to use it about 5 years ago dont know if it still exists. might be worth a hunt round the MS site for it.
Prodused a page that is independant of browser.
Message 2 of 6
(225 Views)
Re: Excel
13-07-2008 11:00 PM
Just a suggestion, as I do not know how "complicated" the Excel sheet is....
Would it not be possible to break it down into say 4 pages, and then re-produce it as a document type file, that could be accessed/presented as a web page, using notepad or similar?
Your viewers would then be able to select the page(s) they needed, and "filter" the information required, using copy and paste?
Message 3 of 6
(225 Views)
Re: Excel
13-07-2008 11:52 PM
Provide a .csv download - like my bank does?
Message 4 of 6
(225 Views)
Re: Excel
14-07-2008 6:52 AM
or indeed as home phone does of the calls made via PN (now that it is working again?)
Message 5 of 6
(225 Views)
Re: Excel
14-07-2008 5:51 PM
Is it an absolute necessity that it is published in Excel? One route you may want to go down is using XML and using XSLT for styling/manipulation purposes.
Message 6 of 6
(225 Views)
