Exceeded webspace bandwidth
- Everything else
- Exceeded webspace bandwidth
02-06-2008 3:55 PM
So do I need to wait until webstats run tonight to find out what happened?
My real question is, why can't Plusnet run a daily limit and just suspend the website for the rest of the day? I am very annoyed that my site uses next to no bandwidth for three years and then without warning it is gone. Fair enough if I push the limits every day but this isn't the case. And why can't Plusnet give a bit more information about what caused the extra bandwidth? Or should I go elsewhere for dependable hosting?
Re: Exceeded webspace bandwidth
02-06-2008 9:05 PM
There is a limit, it is set that in 24 hours, your website cannot have transfered over your Products Allowance in that 1 Hour Period.
I had a Warning EMail for the same apparent "over use".
It turned out to be a Server Calculation Error not only with my website but a number of Customers webspace.
The way you can provide yourself with better backup for the next time this might possibly happen,
is to add Webstats which are not reliant upon the inhouse PlusNet figures to give it a double check.
I found that I had Screenshots (which were 1.6mb) being transfered by Search Engine Robots, daily consuming MB's of Bandwidth.
(This is why you usually have to create a robots.txt in your webroot)
I have prevented any Directories being read by the likes of Google, Yahoo for Caching Image Files... and restricted from sections of my website entirely.
I even went to the trouble of writing a script to compress for Thumbnail Views and disallow direct References to Image Paths.
I can simpathise with your position as it is shocking when you have no idea until the stats are generated,
as to what could (concieveably) have consumed all the data limit.
Good luck,
Jim,
03-06-2008 10:34 AM
06-06-2008 7:41 AM
My site has been down about 3 times this week due to exceeding bandwidth.
I have uploaded .htaccess (stopped all pics loading even for me) and also have robots.txt
Having no luck at all and very very annoyed. Currently looking for a new ISP or hosting service.
Anyone have any solutions?
P.S. running webstats & most traffic is US commercial.
06-06-2008 12:15 PM
HTH
06-06-2008 12:25 PM
"Your website has exceeded its bandwidth allowance"
I get this message everytime. My site is built using filtered html.
Any suggestions?
06-06-2008 4:59 PM
27-06-2008 7:21 AM
Continuing to get the same messages, even though I have reduced the image sizes, text sizes etc etc.
Any bright coders want a task???
Cheers
Dave
27-06-2008 9:59 AM
27-06-2008 12:02 PM
Getting silly now, 3-4 times a week
27-06-2008 12:41 PM
27-06-2008 1:39 PM
I got squeezed out of my last plan & was forced to upgrade.
25-07-2008 5:30 PM
- Everything else
