EPP domain transfer authorisation code request
thefrog2020
I would like to transfer my Plusnet domain out please
9 REPLIES 9
Gel
Champion
Fixes: 29
Re: EPP domain transfer authorisation code request
RealAleMadrid
Fixes: 68
@thefrog2020  I would suggest posting in the "Everything Else" forum board you should get a staff response there, may not be that speedy.🙄
Fixes: 387
And ringing CS probably isn't the best idea - few of them wiil know what you are talking about as domains are a 'legacy' - no longer supported - feature.
Fixes: 479
Moderator's note:
Thread moved from Email to Everything Else
Fixes: 250
To be clear, an EPP is only required for .com domain names.
.*.uk names just need the ISPTAG changing to that of your new registrar.
Either can be triggered from here, but you need to be clear about which is required: some users have been in receipt of bad information and have requested a EPP where a ISPTAG name change is required.
thefrog2020
Ok thanks so how do I change the ISPTAG please?
thefrog2020
My domain is ‘thefrog.plus.com’ so which do I need to change please and how do I do that?
thefrog2020
To clarify, If my domain is .com do I need an EPP or ISPTAG changed and how can I get this done? Thanks
Fixes: 250
That is not YOUR domain, it is not a migratable domain, it is PlusNet's domain and it cannot go anywhere.
What is it you really want to achieve?
