Doman Transfer out
JasonPk306
Doman Transfer out
Hello,
I'd like to transfer my domain name out, and I have seen this is the place to request a ticket.
It's a ".co.uk" domain so I understand I just need to give you the new IPS tag, which is
 NAMECHEAP-INC
Regards,
Jason
Tags (2)
3 REPLIES 3
Penny
Fixes: 9
Re: Doman Transfer out
@JasonPk306 wrote:
Hello,
The support guys will need your domain name - hopefully one of them will send you a PM to ask for that, or if you have no objections to posting it here, they'd probably be able to action the transfer more swiftly.
From recall I believe it takes somewhere around three days (NetOps?) after one of the support guys has input the request.
You should be able to check the ongoing progress via https://www.domaindiagnosis.com/
Penny Rollo * * * joined Force9 on 17/02/98 * * * with PlusNet from 2000 onwards * * * * personal website at pennymidasrollo.plus.com
Superusers are not PlusNet staff but do have a direct line of communication into the business to raise issues, concerns and feedback from the Community.
JasonPk306
Thanks Penny, ok I'll wait for the PM,
Jason.
MatthewWheeler
Fixes: 503
Hi @JasonPk306
I'll drop you a PM shortly to get the ball running
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
