Domain name transfer in
- Everything else
- Domain name transfer in
07-10-2008 3:32 PM
Unfortunately the people who made the website for us are not being very supportive with the changing over of the hosting so I have got Nominet to change the IPS tag to FORCE9. The change is now visible on a whois search but when I go to transfer in the domain I get the message There's a problem with your details, Please enter a name or company name as the registrant. I have filled in all the details correctly on the page and was wondering if it is a case of needing to wait 12-24 hours It has been less than this but because the tag seems to have changed on the whois search I was wondering if there was something I'd done incorrectly.
Regards
Adam
Regards
Adam
Message 1 of 3
(1,156 Views)
2 REPLIES 2
Re: Domain name transfer in
21-10-2008 11:59 AM
Hi Adam
Did you resolve this by going to Nominet?
I'm have the same problem with current domain registrar
Message 2 of 3
(367 Views)
21-10-2008 8:57 PM
Hi
I had this problem when importing from another hosting company.
I had the same error, when all details entered were correct.
If you open a ticket with support they will do it manually for you.
Hope this helps.
Andrew
Hope this helps.
Andrew
Message 3 of 3
(367 Views)
- Everything else
