Domain Name
yfront
Re: Domain Name
Hi Matthew
We've decided to go with Zen for the hosting.
We've confirmed this on the littleclowns account with the Zen tag.
Question #238084842
Hoping this is all achievable and many thanks for you and colleagues help.
Fred
ClaudiaG23
Fixes: 25
Re: Domain Name
Hi @yfront I've raised this for you with the new ISP TAG. This can take up to 72 hours and then your new host can take the domain over.
 Claudia Garner
bobpullen
Fixes: 330
Re: Domain Name
From what I can tell, the IPS Tag was never changed in the first place, so I don't think Hostinger were necessarily to blame for the original problems 😕
yfront
Re: Domain Name
Thanks for the heads up on that.
Does that mean we'll see the tag change on "whois" prior to being able to transfer the domain over?
I think the move to Zen would have been the wiser move in the first place.
Bob - I remember you dealing with problems for me over 20 years ago, you must be well and truly embedded into the office furniture by now.
Fred
MatthewWheeler
Fixes: 503
Re: Domain Name
Hi @yfront
I believe that's right once it's done they should be able to bring it over.
We've had to re-raise the request due to internal changes on our end but as soon as we know more we'll be in touch
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
yfront
Re: Domain Name
Nudge, Nudge.
72 hours+ and nothing seems to have happened!
Just a shot in the dark.
The domain registration is due for renewal on 21/12/23.
Is there any embargo on moving close to the expiry date?
Penny
Fixes: 9
Re: Domain Name
@yfront wrote:
Nudge, Nudge.
The domain diagnosis site shows the registrar as Zen - see https://www.domaindiagnosis.com/index.php?query=memorablemomentsnursery.co.uk
Last updated 15/11/23, it says.
No knowledge of the Zen set-up, but guessing you might need to make all the other required changes there.
Penny Rollo * * * joined Force9 on 17/02/98 * * * with PlusNet from 2000 onwards * * * * personal website at pennymidasrollo.plus.com
Superusers are not PlusNet staff but do have a direct line of communication into the business to raise issues, concerns and feedback from the Community.
willcutforth
Fixes: 113
Re: Domain Name
I have to wait for Matt to come back in as I am unable to view the task for some reason but he is back tomorrow.
 Will Cutforth
Fixes: 580
Re: Domain Name
@willcutforth @Penny s post shows the IPSTAG has been changed.
@yfront now needs to get Zen to confirm the transfer and then eventually use the Zen control panel to change the nameservers to Zen's.
willcutforth
Fixes: 113
Re: Domain Name
No worries, I'll bow out of this one @MisterW ! Good morning, and in case I don't see ya: Good afternoon, good evening, and good night!
 Will Cutforth
ghamilton123
Re: Domain Name
Would recommend instead of using Zen directly to add cloudflares free plan, to speed up load times.
yfront
Re: Domain Name
Thanks everyone for your help.
We're in touch with Zen for them to their part of the domain transfer.
I'll confirm here, hopefully early next week that all is well.
yfront
Re: Domain Name
Website now up and running with Zen.
Thanks for everyones help, special up tick for Penny.
Fred
