Does Plusnet still support Usenet groups?
- Everything else
- Does Plusnet still support Usenet groups?
14-05-2024 4:18 PM
I used to access a few Usenet groups via news.plus.net and Thunderbird but haven't done so in some time. Trying just now to set up a new account on a new installation of Thunderbird didn't get me very far: does Plusnet still support Usenet? I rang the general helpline number to enquire and the (otherwise helpful) operative I spoke to had no idea what I was talking about.
Many thanks.
Re: Does Plusnet still support Usenet groups?
14-05-2024 4:48 PM
Plusnet has some agreement with Giganews to supply text-base newgroup access.
It used to be easy to find Plusnet help pages with the required configuration details (server names etc.) but searching now I can't find the web page. The settings I'm using are:
server: news.plus.net
port: 119
connection security: none
Note: there's currently some problem with the server, which is asking for userid/password for connection. When working properly the server does not require userid/password as it authenticates based on your IP address which is allocated by Plusnet. This problem happens from time to time, and is generally gets fixed in a couple of days.
Regards,
Mike.
14-05-2024 4:54 PM
Mike,
Thanks for that. The current login problems may well be the sole cause of my difficulty.
May I ask what newsreader you're using? I find Thunderbird very unfriendly but haven't really looked into alternatives.
Bert
15-05-2024 2:39 AM
I use SeaMonkey, which I believe uses the same code base as Thunderbird. (So if you don't like Thunderbird I think you wouldn't like SeaMonkey!)
Mike.
15-05-2024 11:57 AM
Yes, the authentication prompt does seem to be the only _immediate_ indication that's something is wrong - but I'm sure the current problem has been there for several days if not longer.
If I try to _post_, I get - usually after a significant time, the most recent one I've kept being 37+ minutes - a "480" (I'm inserting the "===" lines here):
Your article could not be posted
Talking to news.plus.net on Tue, 14 May 2024 23:35:17 +0100
<<< 480
On examination of the "message delivery status" below that, I see
Reporting-MTA: dns; 255soft.uk
Action: failed
Status: 5.0.0
Remote-MTA: dns; news.plus.net
Diagnostic-Code: nntp; 480
Last-Attempt-Date: Tue, 14 May 2024 23:35:17 +0100
If I try to _receive_, I get the "Authentication required for news.plus.net" message, but of course I only see this if I have the log window my software provides open, which normally I do not; I am therefore normally unaware that anything is wrong.
Has anyone raised a ticket? I'm reluctant to do so, as I'd have to go through the usual education process of someone who has never heard of usenet.
15-05-2024 5:07 PM
I don't think there's a ticket, but there's a Forum post for the problem:
In any case, the problem has gone away for me, so hopefully it is fully fixed now.
Mike.
15-05-2024 5:17 PM
Until next time. (Someone in that thread suggested it happens every six months, and asked [Bob?] if they knew of anything that happens with the supplier [which would be Giganews] every 6 months.)
One can't help wondering if it's deliberate to see how many complain🙁
16-05-2024 6:41 PM - edited 16-05-2024 6:42 PM
I'm pleased to report that I appear to have solved the problem: I completely uninstalled Thunderbird and started again from scratch. As before, the setup wizard accepted the account details, though (again as before) it bafflingly reported the username as "mail". I left it at that, but changed the port number from the given 119 to 110 (as used by Outlook for my main email account), and from there on, everything worked: for the first time, I wasn't prompted for login details.
Thanks to everyone for the thoughts and suggestions.
17-05-2024 12:51 AM
Hmm, port 110 is not right for Usenet, and doesn't work for me. It sounds like you might have set up an email account rather than a news server account? When you select "add account" I would expect you to see a couple of options including "email account" and "newsgroup account". You would select the newsgroup option, and enter details as in my earlier post (including port=119 which should be the default anyway...)
OTOH if you're happy with the way you've got it working, who am I to suggest changing anything! ![]()
Mike.
17-05-2024 11:38 AM - edited 17-05-2024 11:41 AM
Mike, thanks for that. I tried changing the port number to 119 (which did come up as the default, you're quite right) and that worked too, so I'll leave it there now. I did definitely choose the newsgroup option when I set the account up.
One oddity: this morning, having left the program running overnight (but minimised), the connection was lost: I had to close and restart the program to re-establish it. Is there a setting somewhere to disconnect after a particular period of non-activity?
Bert
18-05-2024 10:47 AM
I would not be surprised if there's a timeout at the server end under such circumstances; inactive but open connections must still use something, even if it's only holding open one of a limited (but hopefully large!) number of ports. Having to restart Thunderbird, rather than just tell it to fetch and that triggers it, to initiate a reconnection sounds a bit poor, though.
- Everything else
