Do PlusNet use CGNAT?
nickshanks
As title says, do PlusNet use CGNAT on new plans? About to join but want this answered. Package is FTTP 1000.
7 REPLIES 7
Fixes: 1,495
Re: Do PlusNet use CGNAT?
Nope, no CGNAT.
IIRC there was a trial many years ago, but it was never rolled out.
Fixes: 1,495
Moderators Note
This topic has been moved from Full Fibre to Everything Else
nickshanks
Simple and straight answer! Thanks!
PlusNet also stopped offering static IPs though, right?
nickshanks
Also any idea if any ports are blocked for forwarding such as 25 (SMTP)?
Fixes: 1,495
Yes, as of last October static IP can't be ordered anymore.
Fixes: 1,495
Nope, I've previously run a mail server at home. Not that I'd advise doing it these days.
Fixes: 583
@nickshanks you will struggle to run a mailserver on a dynamic IP. It will be on the PBL and you wont be able to set rDNS.  If you are thinking of running a mailserevr then you might want to look at A & A L2TP service https://www.aa.net.uk/broadband/l2tp-service/
You might even get away with the Business light 3Mb/s limit for just a mailserver ?
