DTMF tones for VOIP
longniddry
DTMF tones for VOIP
I have 6 phones using VOIP, they are fine on another network but using plusnet they will not pass DTMF, so users cannot select option 1  etc during a call. Is there a setting in the router to change?
I called plusnet support only to be told they have not been trained in voip so cant do anything. No 2nd line support either
7 REPLIES 7
Fixes: 585
Re: DTMF tones for VOIP
Which router do you have ?
longniddry
thanks, Plusnet Hub two
Fixes: 585
The only setting that relates to voip (sip) is SIP ALG on or off. Its in the advanced>firewall>configuration settings. I would normally suggest it should be off, try changing from whatever it is. I'm not sure it would affect dtmf signalling though....
longniddry
thanks I will try, but I have my doubts on that one. Had to change it on another router for a different purpose
thanks for your help
Fixes: 585
I doubt it as well. I really can't see why dtmf signalling should be any different using plusnet.
I assume the plusnet connection is a similar speed and latency to the other which works ?
longniddry
yes much the same, they were using 4g previously
Fixes: 480
Moderators Note
This topic has been moved from Broadband to Everything Else
