DNS servers offline?
Moongrazer
Re: No broadband
If you're technically minded you can switch your device (or your router) to use alternative DNS like Cloudflare (primary DNS 1.1.1.1, secondary DNS 1.0.0.1) - instructions here: https://1.1.1.1/dns/
heathergail1965
Re: No broadband
Down In Cumbria since 20:45. Typical it goes down when the call center is closed
Bree
Re: No broadband
Mine has literally just crashed. Error message is ‘Connected without internet’ and ‘Plusnet access control disabled’. I work from home so hope this is resolved quickly
HPsauce
All Star
Fixes: 5
Re: No broadband
Yup, looks like PlusNet  DNS is down. Changed my PC to use Google and it's fine.
Can't seem to be able to do that to my PlusNet router though, configuration isn't changeable. It's a Hub One.
GlitterChick
Re: No broadband
We are offline too. Annoyingly!
If it’s just DNS surely there’s a way to change the router.
Plusnet Hub One | Software version 4.7.5.1.83.8.289.1.3 | Last updated 15/12/21
Moongrazer
Re: No broadband
On the Hub Two you can override the DNS servers in IPv4 Configuration. I can't remember what the Hub One has in that regard - though thinking back I do recall you're locked into the default DNS servers unfortunately.
At least you can override it per device, even if it's more of a faff.
mikeyd
Re: No broadband
Yeah.  As above Plusnet DNS is down.  I've changed my router settings to use 8.8.8.8 which is google's DNS server. I'm using a tplink modem though, not a plusnet supplied one.
GlitterChick
Re: No broadband
I wasn’t aware there was a Hub Two. I need to investigate. (We have a One.)
Moongrazer
Re: No broadband
You get the Hub Two with a Full Fibre install.
Aliseries
Re: No broadband
Thanks that worked a treat.
pugalugarug
Re: No broadband
Down as well for a good half an hour, I'm unable to even access the hub manager though which seems odd.
Is there actually no way to contact Plusnet out of hours?
bluewhale
Re: DNS servers offline?
annoyingly can't set the dns servers on the bt smart hub i'm using, grrrr
fixed on a singe laptop
colbrad
Re: No broadband
Been down for last 30minutes here in DN4. Thanks to @Moongrazer I am back online 👍
DerekW
Re: No broadband
Same here in Edinburgh
According to sources it is a widespread outage
I changed my DNS to Googles to get myself back online
8.8.8.8
8.8.4.4
"No one has ever become poor by giving" - Anne Frank
Fixes: 1,495
Moderators Note
Topics Merged
