rDNS change
mrv1
rDNS change
I have a static IP and would like to change the DNS entry for it. Where can I do this?
2 REPLIES 2
Fixes: 580
Re: rDNS change
@mrv1 Here!
One of the Plusnet staff will pick this up and raise a 'ticket' to which you can reply with what you wish the rDNS changing to.
Options are either <ip address>.plus.com or a domain reverse ptr. For a domain address you need to have already created the A record (forward ptr) on your domain to point to your static IP
ClaudiaG23
Fixes: 25
Re: rDNS change
Hi @mrv1 I'll drop you a PM with the information we need to get this changed for you.
 Claudia Garner
